07-12-2019 11:22 - last edited on 07-14-2019 15:29 by LiliyaFitbit
I performed an update on my Ipad (unrelated to my Versa) and my Versa Lite went crazy. The screen started pixelating, and I couldn't do anything with it. Now the Fitbit will do nothing. The only thing that will come up on it is 0% battery, although I have fully charged it. When I try to sync it to the Fitbit App the app can't find the Fitbit. Any suggestions?
Best Answer07-14-2019 15:37 - edited 07-14-2019 15:39
Welcome to the Fitbit Community @Luanmo. I am sorry for the delayed response.
I appreciate your participation in the Forums and sharing the details of the issue you've experienced with your Fitbit Versa Lite after you performed the latest update on your iPad. I appreciate your efforts to resolve the issue. Please try to charge your device by following these steps including a restart: Why isn't my Fitbit device's battery charging?
If the issue still persists, I recommend doing a factory reset. Please note that you'll need to reinstall any apps on your device after the reset, and if you couldn’t sync your device, then any data on the Fitbit device will be lost. In order to do the factory reset, please do the following:
Let me know how it goes, I'll be around!
07-17-2019 18:59
07-17-2019 18:59
07-17-2019 20:09
07-17-2019 20:09
Hi @Luanmo, thank you for your reply!
I am glad to hear the issue is resolved. If possible, please mark the answer given as a solution. By doing this, other users with the same inquiry will be able to find a faster response. I appreciate your time and efforts and hope you continue enjoying your device and working on your goals.
Have you checked our Discussions board? There you can share your story, find some fitness tips, recipes and more! Give it a look!
Enjoy the Fitbit experience. Keep on visiting the forums! ![]()
Best Answer03-16-2020 07:39
03-16-2020 07:39
your answer didnt work
03-16-2020 07:54
03-16-2020 07:54
i have bought versa lite edition and using it on iphone it worked for 3 days after i updated app worked for 4 hours and all of a sudden screen went off and in app it shows device not found and if i charge it shows 0 % but on that day only it was charged to 100% after few days it automatically turned on and worked for one day and again screen went of and in app it shows device not found and if charged 0% i have tried long press the back button for 10-15 second no use and pressed back button for 8 sec and released for 2 sec and pressed again but no use
03-16-2020 16:27
03-16-2020 16:27
Welcome to the Fitbit Community, @rajeevintety.
Thank you for joining the thread and sharing the details of the issue with your Versa Lite. I appreciate your troubleshooting efforts. Since the steps you tried didn't work, I've gone ahead and escalated your case to our Support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
Let me know if you have any questions.
Best Answer03-19-2020 06:25
03-19-2020 06:25
Hello
I bought Fitbit verse on dec 2019 and then went to out of country. Today I came back and I put charging and then try to sync. Unfortunately it is not even starting. No logo nothing appears on screen. As per above instructions I was trying to do hard reset but nothing is working. First time I am starting. Please help me .
thanks
Best Answer04-15-2020 00:52
04-15-2020 00:52
My screen is black! Nothing is showing. The app for settings doesn’t have an option to restart and when I do the restart through the device itself I cannot see when I press the button if the device has restarted or not! Everything still works though. I bought it through Amazon and only had it for two months! How can I get this resolved?!
thank you
Best Answer04-25-2020 16:32
04-25-2020 16:32
I tried the reset, the second time I held the button I did get a long vibration but then nothing. Now I can't even get to that point. Totally dead and yes it is charged. Please let me know if there is anything I can do, it is less then a year old.
Thanks,
JudiLL
04-26-2020 11:44
04-26-2020 11:44
Welcome to the Fitbit Community, @Nag-versa @Tinanino @JudiLL. I am sorry for the delayed response.
@Nag-versa I appreciate your participation in the Forums and sharing that your Fitbit Versa is not turning on. Thank you for your efforts and the additional details. I recommend following our complete troubleshooting instructions from this help article: Why isn't my Fitbit device's battery charging?
@Tinanino thank you for joining the thread and sharing the details of the issue with your watch. I totally understand how you are feeling and appreciate your troubleshooting efforts. Upon checking with our Support team, I was told that you have already contacted them and that they were able to help you. Thank you for your time and efforts.
@JudiLL I am sorry to hear your watch won't turn on. Thanks for trying to resolve this and I am here to help. I would to confirm the steps you tried to restart your device: How do I restart my Fitbit device? Please also try switching to a Fitbit clock face if you're using a third party clock face: How do I change the clock face on my Fitbit device?
Keep me posted on the outcome.
Best Answer04-30-2020 19:42
04-30-2020 19:42
My daughter has a Versa Lite and I did a factory reset so I could use it for myself, but it never came on after the reset. Now it is dead. I tried charging it for 2-3 hours, but still nothing. I’m not even sure it is charging. Please help! This is a barely used Fitbit, bought in October 2019.
Best Answer05-01-2020 17:35
05-01-2020 17:35
Welcome to the Fitbit Community, @Kexline.
Thank you for joining the thread and sharing that your daughter's Versa Lite won't turn on after factory reset. I appreciate your efforts to resolve this, I totally understand how you are feeling and I am here to help. I recommend following our complete troubleshooting steps in this help article: Why isn't my Fitbit device's battery charging?
Let me know how it goes, I'll be around.
Best Answer05-01-2020 17:49
05-01-2020 17:49
@LiliyaFitbit Thank you for the tips. I have tried all the solutions under the article you suggested and still nothing. I left the Fitbit on the charger over night too and still dead. What do you suggest next?
Best Answer05-01-2020 17:56
05-01-2020 17:56
Thank you for your reply, @Kexline.
I appreciate your efforts and the additional details. Since the issue persists, I've sent your information to the Customer Support team so they can get in touch with you and provide further assistance. You should be getting a reply soon.
Best Answer05-21-2020 16:29
05-21-2020 16:29
i bought my Fitbit Versa Lite summer last year and up until january it has been working no problem. I installed this Fitbit app update in February and I have not been able to use it since!
The screen is now completely black, the device itself will not charge I have uninstalled and reinstalled the app, hoping for another update. It will not find the device and when it does it will only show life on the screen when it is in the charger.
The app is staying that the device is full charged but once you take it out of the cradle it turns off. I have tried the factory reset indicated above, but this doesn't work! I have held the button In for practically a minute with no recognition from the device what so ever.
This is the second Fitbit that I have had problems with.
Best Answer05-21-2020 22:26 - last edited on 05-22-2020 19:00 by LiliyaFitbit
I have given replacement but its asked to pay the customs duty
Moderator edit: format
Best Answer05-22-2020 19:10
05-22-2020 19:10
Welcome to the Fitbit Community, @FoofeePants. It's nice to see you around, @rajeevintety.
@rajeevintety I am sorry to hear that you're being asked to pay the customs duty for your replacement device. I could see that you got in touch with our Support team about this. I know they will be glad to help you out and provide a solution, just keep an eye on your inbox.
@FoofeePants thank you for joining the thread and sharing the details of the issue with your Versa Lite. I am sorry that you are going through this situation. I appreciate your troubleshooting efforts and would like to confirm if you're using the Fitbit designed clock face and if you've followed the complete troubleshooting instructions at Why isn't my Fitbit device's battery charging?
Looking forward to hearing back from you.
Best Answer05-23-2020 02:11
05-23-2020 02:11
Thank you for replying to me, I have followed all the advice for charging my fitbit to no avail!
I have not changed my clock face since I bought the device, and I dont see what that would have to do with the working of my device. It stopped working when the new app update was done.
I am now left with a device that I can not use. I have tried it on other phones too and it still wont work .. trying to sync the device will show that the battery is full charge but once you take the device out of the cradle it stops working again
Thank
Best Answer06-15-2020 01:31
06-15-2020 01:31
Hello I am having some issues as well.. it just synced 20 mins ago. I looked down and all I am getting is the logo going on and off the screen. It still has life according to my app. I put it on the charger and there is no indication that it's even charging like usual. I am holding the button thinking I too could do a reset. It does not turn off or vibrate and only blinks the logo on for about 20 seconds off for about 5. Please help this one isn't that old since it was recently replaced by fitbit for a detected screen.
Monique
