05-13-2018
10:42
08:14
AlejandraFitbit
05-13-2018
10:42
08:14
AlejandraFitbit
So angry and frustrated. My Versa (less than a month old) has died this morning, nothing, nada, zero, blank screen. It won't charge up it won't do anything. It was fine yesterday with a full charge not this morning nothing and I lost a whole work out!
07-15-2018 11:28
07-15-2018 11:28
07-28-2018 23:38
07-28-2018 23:38
Thank you! Fixed my problem 🙂
07-29-2018 08:38
07-29-2018 08:38
They is nothing better dan smile just make people happy so that you can be happy too
08-05-2018 13:22
08-05-2018 13:22
I got my Versa 3 months ago and am replacing it for the second time. They will not give me a refund or a different product. My only option is another Versa. My advice is stay away from the Versa. If Fitbit was a decent company they would recall the Versa and replace it with something that works. Instead I will just keep getting it replaced as long as they keep breaking. Very frustrating. I’m very disappointed with this company
08-08-2018 15:34
08-08-2018 15:34
My 2 month old Versa screen will not go on. Was skipping before it went blank and battery according to my fitbit app is fully charged.
08-08-2018 21:16
08-08-2018 21:16
This is my second Versa (first one had battery issues). Replaced by BestBuy. This morning the screen died. I can still feel it vibrating but resetting using the buttons it does nothing. Tried also to charge it up/change faces etc, all to no effect.
Just took it to BestBuy to replace it again and they did, but they said that Fitbit no longer allows the BestBuy extended warranty on this fitbit. Probably too many issues. I have my new replacement, but Im out of luck if anything else happens to it.
08-18-2018 19:06
08-18-2018 19:06
The same thing has happened to me. Hard reset is not working. Fitbit was working fine and today the screen went black and wont come back on. It was at full charge this morning so that is not the issue. Please help
08-18-2018 23:13
08-18-2018 23:13
08-19-2018 03:06
08-19-2018 03:06
08-22-2018 22:40
08-22-2018 22:40
ive Tried the factory reset numerous times but still nothing happening!
This is my second watch innonly a few months
08-24-2018 15:23
08-24-2018 15:23
thank you worked for me 🙂
08-24-2018 19:45
08-24-2018 19:45
08-31-2018 04:16
08-31-2018 04:16
I am having the identical issues. This started yesterday with mine. I can't find any solutions at all. Any suggestions?
08-31-2018 06:33
08-31-2018 06:33
08-31-2018 07:50
08-31-2018 07:50
08-31-2018 08:41
08-31-2018 08:41
08-31-2018 12:01
08-31-2018 12:01
09-01-2018 00:23
09-01-2018 00:23
09-01-2018 01:55
09-01-2018 01:55
09-13-2018 13:59
09-13-2018 13:59
I've had this versa Fitbit for a day went to set it up and it wouldn't sync to my phone so I tried a factory reset like it said to do and now I have a blank screen. I put it in the cradle charger and it will eventually show the Fitbit logo but doesn't seem to be charging or at least the charging light is not on please can someone help?
