04-11-2019
17:47
07:02
AlejandraFitbit
04-11-2019
17:47
07:02
AlejandraFitbit
My Versa all of a sudden has striped lines going down the middle.
Moderator edit: subject & format
04-11-2019 21:12
04-11-2019 21:12
Welcome to the forums!
Try a restart. Do it at least 3 times.
Keep us posted!
Wendy | CA | Moto G6 Android
07:02
09:28
04-12-2019
07:02
09:28
A warm welcome to the Community @deannanicole76 and @WendyB thanks for the input.
I was able to see here that our friend @WendyB provided some instructions in order to fix this screen issue. Was this the answer you were looking for? If it was, I recommend marking the answer given as a solution. By doing this, other users with the same inquiry will be able to find a faster response.
Now if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out.
Best Answer04-12-2019 13:46
04-12-2019 13:46
I'm having the exact same problem. Tried to restart multiple times, but nothing changes
Best Answer04-12-2019 15:29
04-12-2019 15:29
I just started having the exact same problem.
04:22
09:28
04-14-2019
04:22
09:28
Hey guys, thanks for your participation in the Community and for troubleshooting this display issue by yourselves.
@Laurenpr, upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
@Medeous, have you tried the restart process? If you haven't, I recommend taking a look at the help article How do I restart my Fitbit device? and follow the instructions provided there.
Let me know how it goes.
Best Answer04-14-2019 07:12
04-14-2019 07:12
I've done the 3 button reset a few times. It will seem to go away and then returns with the vertical lines five minutes later. I did a factory reset and went through setting it up all over. It came back. Not sure what else to do at this point.
Best Answer04-15-2019 01:01
04-15-2019 01:01
Hi mine is exactly the same. I’ve spoke to them at customer service and they are sending me a new one ! I’ve only had mine 3 months and I’ve tried all the resets .
Best Answer04-15-2019 10:08
04-15-2019 10:08
This is my second one that has done this 😒 They are also sending me a new one:) The customer service has been great.
