09-05-2018
02:46
06:07
AlejandraFitbit
09-05-2018
02:46
06:07
AlejandraFitbit
What is going on with the sleep tracker all of a sudden? The Versa was tracking my sleep wonderfully until about a week or two ago. Now it either doesn't track or says I've been up for hours during the night, which I know isn't correct. My Samsung Gear 2 never had this problem. Was there an update that I wasn't aware of that's messed this up? I'm about to send this watch back and go with another brand. This was a big part as to why I bought this. Nothing has changed in how I've been wearing it. What's happened? Anyone else experiencing this?
02-18-2019 11:16
02-18-2019 11:16
Exactley! The whole point of having the Versa is for it to track everything for you, not have to manually enter or edit. Not impressed at all with Versa. I never had issues with Charge 2. It seems the new versions they come out with have more and more problems.
Best Answer02-18-2019 19:19
02-18-2019 19:19
Holding down all three buttons seems to have fixed the heart rate problem at least. We’ll see if it solves the sleep tracking issue too. I’ve been without it for a week now.
02-19-2019 00:15
02-19-2019 00:15
My husband is having this problem on his Versa.
any ideas????
Best Answer02-19-2019 00:36 - edited 02-19-2019 00:41
My versa stopped tracking my sleep on Sunday. What has changed Fitbit?
My heart rate monitor also stopped at the same time. I have held all 3 buttons as suggested by another poster - heart rate monitor back on line, will find out tonight if sleep tracking working again or not.
Best Answer02-19-2019 01:04
02-19-2019 01:04
Best Answer02-19-2019 15:15
02-19-2019 15:15
02-19-2019 16:26
02-19-2019 16:26
I’m having sane issue since sunday no sleep tracking. Today heart rate. Trying 3 button reset. Reinstalling app did nothing.
Best Answer02-19-2019 16:52
02-19-2019 16:52
Hi, Just bought a versa while sleep is being tracked I am unable to get REM data. How does one fix this? thanks
Best Answer02-19-2019 18:00
02-19-2019 18:00
worked for me too!
Best Answer02-19-2019 18:11
02-19-2019 18:11
Mine stopped tracking sleep stages since 13 Feb, only shows sleep patterns. I simply wear the device to sleep with proper fitting and fully charged. My versa also stop green flash to detect my HR. I've tried including shot down and restart, three bottom reboot, and factory reset; nothing worked!
I found that Fitbit released an update. After installed and restart my versa, the HR tracker seems working normal now. We'll see if the sleep tracker problem solved or not.
Best Answer02-19-2019 18:20
02-19-2019 18:20
Best Answer02-19-2019 18:45
02-19-2019 18:45
I have to correct myself. After updated the app and restarted my versa, the heart rate showed few minutes but went down again!
23:45
07:54
MarcoGFitbit
02-19-2019
23:45
07:54
MarcoGFitbit
Thank you for your reply.
Did 3 Button reset yesterday and the Versa recorded ALL sleep last night.
This seems to be a recurring problem with the Versa, come on Fitbit get it sorted.
UPDATE:
My husband is having trouble with this update, his screen is telling him “we were unable to update/install one or more apps please try again”
What does this mean and how can he go forward with his update / installation?
UPDATE 2:
If this persists you should contact Fitbit direct.
I had a load of trouble with my first Charge2 and contacted Fitbit chat, they were fantastic, I was really impressed with their customer care. I persevered and my fourth replacement Charge2 is working fine now. You do have to be like a dog with a bone, but worth the inconvenience.
Best Answer02-20-2019 01:56 - edited 02-20-2019 02:04
Morning all, update:- So after 3 button press yesterday kick starting the heart rate tracking, I was left with finding out if my sleep would be picked up again. This morning my versa didn't show my sleep stat from last night but when I synched with app everything showed up on both phone app and on Versa.
Thanking you all for advice and positivity. 😀
Best Answer02-23-2019 07:58
02-23-2019 07:58
Hello @mysticquest, @Caracast75, @Lmsg, @Grrry, @Cher9498, @Mimi1966, @cmbarnes17, @TheatreKat, @FergieFromFife, @princessabroad, @Loucamille, @Bullet65, @blondie761, @littlehappy, have a warm welcome to the Fitbit Community, it's great to have you on board. ![]()
First of all, I'd like to apologize for the delay in the response. I appreciate your participation in the Forums and for sharing your experience with us. At this moment, our team is aware of these issues affecting your Versa and @FergieFromFife, our team is currently investigating the issue with the Fitbit app.
I appreciate some of you have come back and let us know that after restarting your Versa everything is working as it should. We'll make sure to let you know in case our team has any updates regarding this situation and we'll make sure to post them here in the official Forums.
If there's anything else we can do for you in the meantime, please let us know. Have a great day.
Best Answer02-23-2019 08:51
02-23-2019 08:51
I'm having the problem - Versa stopped tracking sleep last night.
Versa is / was charged.
Wearing it at same place on my wrist.
Bluetooth is working, steps, heart rate is syncing.
I turned on off Versa 3 times.
Turned Bluetooth on/off.
No Sleep tracked on Versa, nor app.
Best Answer02-23-2019 09:06
02-23-2019 09:06
02-23-2019 13:47
02-23-2019 13:47
Best Answer02-23-2019 22:37
02-23-2019 22:37
Hi all,
Many thanks for all your tips. I finally got it working- stopped using the Sleep App. Versa automatically tracks sleep and syncs with the app in the morning. Cheers
Best Answer02-24-2019 00:00
02-24-2019 00:00
