06-25-2018
05:31
08:24
AlejandraFitbit
06-25-2018
05:31
08:24
AlejandraFitbit
When I tap the screen on my Fitbit Versa, nothing happens. The buttons will still work, but I cannot tap the screen or scroll at all. I have tried syncing and resetting but nothing has worked. Any advice is appreciated!
Moderator edit: subject
Best Answer06-25-2018 07:48 - edited 06-25-2018 07:50
Assuming when you say "resetting" you are talking about a Restart, try it several times if necessary. If that doesn't work, all that's left is a Factory Reset reached by swiping right to Settings, then About and then Factory Reset which puts the watch back to the way it was when you unboxed it.
EDIT: I just reread your post and if you can't scroll to the Factory Reset setting, do it the 3 button way described below:
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time or otherwise don't follow the procedure precisely , the Fitbit logo reappears quickly and boots without factory reset
06-27-2018
08:25
17:31
06-27-2018
08:25
17:31
Great to see new faces @javes20, welcome and @SunsetRunner thanks for the input.
I appreciate all the efforts in trying to fix the display issue you are experiencing and would like to know if the instructions provided by our friend worked or if you keep having problems?
Hope to hear from you soon. ![]()
06-27-2018 08:33
06-27-2018 08:33
Yes, I have tried all of the proposed solutions and nothing seemed to have worked. I reset several times and tried to factory reset. I called customer service twice, sent videos of what was wrong and nothing was working. Fitbit is now mailing me a replacement one!
06-28-2018
07:45
13:51
06-28-2018
07:45
13:51
Those are great news @javes20, I am glad to hear that you will be receiving a replacement. At the moment of receiving it, you just need to do the following from your Fitbit app to set it up:
Happy stepping. ![]()
04-08-2019 16:29
04-08-2019 16:29
Thank you,
I was having the same touch screen issues with my versa for few days now, I followed your instructions and it works. Screen seems to be responding faster than before.
Thanks again 😊
12:51
17:32
04-09-2019
12:51
17:32
Hello @Weakenfalls thanks for joining the conversation, it's great to have you on board the Fitbit Community. 🙂
I appreciate you have taken the time to join us and let us know the instructions provided by @AlejandraFitbit were helpful to you. I'm very glad.
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
04-22-2019 06:03
04-22-2019 06:03
This has also happened to my fitbit. I have tried several times to restart using the 3 button method but no vibration occurs when I release the bottom right button.
Do I keep trying this or is there something else I need to do?
04-22-2019 15:28
04-22-2019 15:28
12:00
17:32
04-23-2019
12:00
17:32
Hello @Weakenfalls and @Sammyam thanks for joining the Fitbit Community, it's great to have you on board.
I appreciate your participation in the Forums and for sharing your experience with us. @Weakenfalls thanks for your tips, I'm sure they will be very helpful.
@Sammyam I have reached our Support Team and it seems you have already created a case with them and they have been able to provide you a resolution, I'm very glad.
If there's anything else we can do for you, please feel free to reply.
04-23-2019 18:41
04-23-2019 18:41
04-24-2019 07:30
04-24-2019 07:30
I contacted the support team using live chat..they were very helpful and talked through several solutions. Unfortunately none worked for me. They confirmed my issue shouldn't happen and are sending a replacement .
Best Answer04-24-2019 08:14
04-24-2019 08:14
Yay😁,
Also did the same thing through the live chat, the tech support was very informative and helpful with my issue. Lucky me that my versa was still under warranty so they processed a replacement for me. I should revrece it in 5-7 days.
Thank you 😊 and have blessed day
11:43
17:32
04-25-2019
11:43
17:32
Hello @Weakenfalls and @Sammyam I hope you're doing well, thanks for taking the time to reply.
I appreciate you have come back and let us know you contacted our Support Team and they will be replacing your devices, I'm very glad.
04-26-2019 12:31
04-26-2019 12:31
How do you get to the live chat?
Best Answer04-26-2019 16:33
04-30-2019 07:31
04-30-2019 07:31
I am having the same issue. I tried resetting several times and still unable to swipe or make selections by touching the screen so I thought I would do a factory reset and I too held all 3 buttons and released the bottom but never did get a vibration indicating a factory reset was initiated. Please help!
Best Answer04-30-2019 07:45
04-30-2019 07:45
This seems to be a common issues with the versa. If I may ask, by any chance your versa got splash with hot or really warm water? It happens to mine while washing dishes and my watch just went dead after that.
Best Answer04-30-2019 14:14 - edited 04-30-2019 14:15
Weakenfalls - no it was not exposed to hot/warm water when it quit working.
Best Answer04-30-2019 14:44
04-30-2019 14:44
