06-25-2018 05:31 - last edited on 06-27-2018 08:24 by AlejandraFitbit
When I tap the screen on my Fitbit Versa, nothing happens. The buttons will still work, but I cannot tap the screen or scroll at all. I have tried syncing and resetting but nothing has worked. Any advice is appreciated!
Moderator edit: subject
04-30-2019 16:36
04-30-2019 16:36
Sorry to hear, again I suggested you guys to reachout to customer service regarding your specific issues, I just received my replacement today in the mail. Use the live chat and tell them what's going on with versa, if your device is still under warranty then u might be in luck of getting a replacement. Side note though, I believe this is a common issues with the versa and also I don't think it's really water proof. Check the seals on the screen
07-14-2019 20:58
07-14-2019 20:58
I am having the same issue, and fitbit screen is dark and unresponsive, even after pushing all three buttons. It did synch with my phone and it appears to be charged.
07-15-2019 10:05
07-15-2019 10:05
Recently I had the same issue after mine was replaced, for the second time they sent me a replacement and so far it's working ok. My suggestion is that reach out to Fitbit via chat live support and see what options you have. After this one I won't be getting Fitbit anymore, I'm going to try something new.
Best of luck with the issues you're having and I know it sucks not having your device function the way it supposed to.
08-27-2019 05:12
08-27-2019 05:12
Hi,Can you pls guide me how to initiate chat with fitbit support team..
08-27-2019 07:37
08-27-2019 07:38 - edited 08-27-2019 07:40
Hope this helps you get your issue resolved
10-04-2019 06:05
10-04-2019 06:05
10-04-2019 09:29 - edited 10-04-2019 09:32
Hey sorry to hear about the issues you're having with your versa. This has been an ongoing issues with the versa. Please contact support via the live chat regarding your issues.
https://help.fitbit.com/?l=en_US
Click on Let's talk at the bottom to open the live chat.
10-15-2019 03:42
10-15-2019 03:42
I'm also having problems with my Versa:
Suddenly (without being exposed to hot water or a shock - I do swim with it)
- the screen tap does not wake up the screen
- the wrist turn does not wake up the screen
I have checked the settings in the app and on the phone - wrist turn IS active.
I have restarted numerous times.
I did a factory reset. (I will probably try that one more time).
I already had my Versa replaced once for a different issue.
If the guarantee is one year...I can't get it replaced.
When it works - I love my Versa, but there seems to be a lot of bugs 😟.
I will contact support now.
12-06-2019 03:50
12-06-2019 03:50
My Versa touch screen is not responding at all. I've tried both resets and my Versa screen is still not responding. I don't know what else to do, and I have had it about 1 year
12-11-2019 18:10
12-11-2019 18:10
I tried this and now my Fitbit Versa won’t turn on 😕
12-18-2019 14:38
12-18-2019 14:38
My fitbit versa screen periodically becomes unresponsive and I have to do 3 button reset. This happens several times per day. Can you please advise?
01-01-2020 12:25
01-01-2020 12:25
I had the same problem - Perfect fix, thank you!
01-29-2020 07:13
01-29-2020 07:13
Factory reset did not work for me. My touch screen is still not working from time to time. This is the worst purchase I've made yet.
02-07-2020 13:56
02-07-2020 13:56
I'm sorry to hear that you're having issues with your versa. Please reach out to customer service and see if you can get a replacement if your device is still under warranty. Unfortunately for me, I've moved away from versa to Samsung Active 2 watch which was the best decision I've made.
02-26-2020 08:17
02-26-2020 08:17
My fit bit screen is not working also. I have tried the restart several times using the 3 button method. The screen only shows the time and will not scroll any direction. Any other tips?
02-26-2020 08:49
02-26-2020 08:49
02-28-2020 12:51
02-28-2020 12:51
04-26-2020 10:13
04-26-2020 10:13
I have tried doing all the things you suggested. I have tried doing a factory reset, but nothing seems to work. The screen comes back, but the taps still don't work. The only saving grace is that it does sync up with my phone.
04-28-2020 14:07
04-28-2020 14:07
I tried restarting AND the three button factory reset. My screen still does not respond.
