04-25-2018
10:02
04:43
AlejandraFitbit
04-25-2018
10:02
04:43
AlejandraFitbit
Now I'm getting annoyed, my Versa is not syncing now ... when connecting back to Bluetooth on phone I am getting 2 different Versa showing up, 1 says Versa & 2nd says Versa (classic), tried both and still nothing ... which one is the proper one to connect? Getting frustrated with things not working, why did Fitbit make these apps so hard to understand and work! grrr ... expensive watch that don't work properly! Nothing but issue problems, hope Fitbit gets everything working the way its suppose to.
04-26-2018 04:44
04-26-2018 04:44
It's great to see you here @PROUD-PSW.
I would like to know if you keep having issues syncing your Versa? If you do, I recommend taking a look at the Having trouble syncing? post and follow the instructions provided there.
I hope this helps, let me know the outcome.
04-27-2018 17:04
04-27-2018 17:04
Hi the suggestion hasn't helped amd to be honest I am finding many issues with the versa that I would have thought would have been tested before releasing it to market. Disappointed.
05-02-2018 04:36
05-02-2018 04:36
A warm welcome to the Community @Emmsy.
Thanks for troubleshooting this by yourself. I would like to know if you have checked if your Fitbit app is updated? If you haven't, I recommend taking a look at the How do I update the Fitbit app for Android? post and follow the instructions provided there.
Let me know how it goes.
05-02-2018 06:26
05-02-2018 06:26
I'm having the same problem. My versa hasn't synced since yesterday and I've tried it all now. Restarted phone, restarted versa, logging out of the app and back in, deleting the app and reinstalling it. Nothing works. What to do?
05-02-2018 07:07
05-02-2018 07:07
My versa hasn't synced in 4 days. That combined with no notifications... I'm about done. Nearly $300 and it mostly doesn't work. So upset 😞
05-03-2018 04:15
05-03-2018 04:15
@Anjarap and @4T1A1E it's great to see you around.
Thanks for troubleshooting this by yourselves. @Anjarap since the instructions you tried didn't work, I've gone ahead and escalated your case to our Support Team, keep an eye on your inbox for further instructions.
@4T1A1E, if you haven't tried the instructions provided in the Having trouble syncing? post, I recommend taking a look at it and follow them. Also, check the My Tracker isn't receiving notifications (Android App) post and follow the instructions provided.
Let me know the outcome.
05-17-2018 07:40
05-17-2018 07:40
I feel the same way. I was very excited to have this device and I thought I did the research. It's so wonky. I was on chat with support for almost an hour last night and cannot get it to sync. It's insane. Some BS about iOS, but when I look up problems online, every operating system is buggy with Versa. It was not tested well before being brought to market. Too expensive for this to be happening. Very disappointed, too.
05-19-2018 14:50
05-19-2018 14:50
I am having the same issues over and over again. The tracker won't sync, it won't remember Wifi selections, keeps saying bluetooth issues and restart bluetooth, and won't consistently get notification. App and tracker are both updated, I have tried restarting both over and over again, and it just won't work more than once in a row. I am returning mine today. Too bad, because I love the device and this is probably my 6th FitBit but I think I am going the Apple watch route for reliability reasons.
05-20-2018 12:40
05-20-2018 12:40
Me, too. I'm a mac user anyway--phone, macbook, etc...I may do the same 😞 . Really pissed off, actually.
05-23-2018 08:40
05-23-2018 08:40
I just had the same issue and my phone was lacking internal storage even though I have an SD card it looks like FitBit uses the built-in storage by default. Try to clear up some space, reboot your phone and do the sync again.
06-06-2018 13:55
06-06-2018 13:55
My Versa is 3 days old and won’t sync.
06-06-2018 18:34
06-06-2018 18:34
Was it syncing before. Several people (including me) have found their Versa suddenly won't sync even though it was previously syncing.
06-06-2018 19:11
06-06-2018 19:11
06-07-2018 15:29
06-07-2018 15:29
Versa is 3 days old, sometimes it will sync, sometimes it wont.
Same thing with wireless, sometimes connects but not always.
Bluetooth always has problems.
Does not receive text notifications.
Very disappointed with the versa.
Probably going to return it.
06-07-2018 15:33
06-07-2018 15:33
06-07-2018 15:53
06-07-2018 15:53
06-07-2018 15:57
06-07-2018 15:57
06-07-2018 16:04
06-07-2018 16:04
What do you mean by (versa classic)? I connected the versa to my bluetooth, but it always has problems reconnecting. I had it connected to my wifi but now when i go to the wi-fi settings in the fitbit app on my phone all i get is a spinning circle, cant get to the setting. I have uninstalled and reinstalled the app.
06-07-2018 16:07
06-07-2018 16:07
