04-25-2018
10:02
04:43
AlejandraFitbit
04-25-2018
10:02
04:43
AlejandraFitbit
Now I'm getting annoyed, my Versa is not syncing now ... when connecting back to Bluetooth on phone I am getting 2 different Versa showing up, 1 says Versa & 2nd says Versa (classic), tried both and still nothing ... which one is the proper one to connect? Getting frustrated with things not working, why did Fitbit make these apps so hard to understand and work! grrr ... expensive watch that don't work properly! Nothing but issue problems, hope Fitbit gets everything working the way its suppose to.
06-07-2018 16:12
06-07-2018 16:12
The only thing i see in settings is bluetooth connection options.
When i go there it say +audio device.
06-07-2018 16:18
06-07-2018 16:18
06-07-2018 16:30
06-07-2018 16:30
Go to the bottom of what?
Always connected and all day sync are on, in the app.
06-07-2018 16:35
06-07-2018 16:35
06-07-2018 17:29
06-07-2018 17:29
Sorry but i don't see what you are talking about. The only bluetooth setting on the watch says +audio device. You say flip it to pair, HOW? I don't see the BT settings you are talking about.
06-07-2018 17:32
06-07-2018 17:32
06-07-2018 18:00
06-07-2018 18:00
I don't see a music via bluetooth. I see music on the watch and if i go there i get a spinning wheel and after a while it says can't connect to wi-fi.
06-07-2018 18:04
06-07-2018 18:04
06-07-2018 19:22
06-07-2018 19:22
Okay, mine was having the same issues. I called Fitbit directly and the tech walked me through a series of steps that are NOTHING like what you all are talking about. Now it works fine. (I wish I could repeat the steps but I can’t remember exactly and I’d hate to miss a step).
06-07-2018 19:23
06-07-2018 19:23
06-08-2018 04:57
06-08-2018 04:57
I have space on my phone. Interestingly, the rep I spoke with did not even mention this as a solution.
It's going back. I'm heading for an Apple Watch. It syncs, it doesn't sync. It monitors HR, it doesn't monitor HR...it's the most fickle piece of technology I have ever had...and I have had a lot of technology.
06-08-2018 10:40
06-08-2018 10:40
06-08-2018 15:56
06-08-2018 15:56
Just called fitbit support and was told the versa is not compatible with my phone.
I have a Moto Z Force. Looks like the only motorola phones that are compatible are old ones, like at least 3 years old. No new phones are compatible. Returning my versa.
06-11-2018 09:59
06-11-2018 09:59
You have a good point. I have been using a Fitbit for 4 years. I tried for days to sync the Versa. Managed to get it syncing, then it was off again. Spent hours on with support. I returned it, but I will continue to check with Fitbit, as to when the issues will to be resolved. So far I have not seen any response or acknowledgment from Fitbit. I want a Versa, but what I got wasn't impressive. I'm back with my old HR.
06-11-2018 10:18
06-11-2018 10:18
06-11-2018 11:19
06-11-2018 11:19
This is the whole issue. Some Versa work fine and other don't. Could this point to a hardware / software issue, or are some made at a different location. Is it a timing issue? I bought one about 4 weeks ago. Is that relevant?
Come on Fitbit - share your assessment of the issue!
06-13-2018 08:58
06-13-2018 08:58
Hello everyone, I hope you're doing well.
I appreciate your participation in the forums and for sharing with us your experience so far with the Fitbit Versa. At this moment if your Versa is still having trouble syncing I would like to ask you to try the following:
If your device still won't sync, try these steps:
If you have already tried these troubleshooting steps and your Versa is still not syncing correctly, my best recommendation would be setting up your Versa as a new device (without removing it from the account first) to reset the connection between your Versa and your phone. Don't worry, none of the information already stored in your account will be deleted.
To set up your watch as a new device:
Thanks for your patience and understanding, give these steps a try and keep me posted in case you need anything else.
06-13-2018 13:20
06-13-2018 13:20
You REMOVED this thread and posted this? EVERYONE ON THIS THREAD HAS ALREADY TRIED ALL THESE THINGS REPEATEDLY!!!! This is the point you all are missing. No one should have to go through all these steps MULTIPLE times a day in order to make this device function AS IT IS ADVERTISED to function. BUY THEM BACK.
06-27-2018 00:03
06-27-2018 00:03
Could you please help me I have done everything all the tips with syncing. It just won’t sync
06-27-2018 07:04
06-27-2018 07:04
Here's my advice:
RETURN IT.
