04-25-2018
10:02
04:43
AlejandraFitbit
04-25-2018
10:02
04:43
AlejandraFitbit
Now I'm getting annoyed, my Versa is not syncing now ... when connecting back to Bluetooth on phone I am getting 2 different Versa showing up, 1 says Versa & 2nd says Versa (classic), tried both and still nothing ... which one is the proper one to connect? Getting frustrated with things not working, why did Fitbit make these apps so hard to understand and work! grrr ... expensive watch that don't work properly! Nothing but issue problems, hope Fitbit gets everything working the way its suppose to.
06-28-2018 14:10
06-28-2018 14:10
I am unable to sync my Versa on either my I-Phone or my computer. I have set up the device as new on my phone - the phone finds the Versa but is stuck now on "Connecting to Tracker" Its been over an hour in that mode. I;ve tried everything you have suggested. Whats the next step? My device is only a month old!
07-02-2018 12:31
07-02-2018 12:31
Very disappointed. Mine is showing that I was awake for 2.5 hours right after going to bed. I know that’s not true. I sleep like a log.
07-02-2018 12:55
07-02-2018 12:55
Called techsupport and they fixed me right up. I did not have to wait long and the rep was very nice
07-14-2018 10:17
07-14-2018 10:17
They’re still having issues with the versa I believe. For the time being, it only works with the iPhone 8 and 10 but the rest of the devices from 2018 aren’t yet supported. I’m not sure what is the logic for taking that much time. Im also facing syncing issues from time to time besides, my watch(Versa) doesn’t notify me to move every one hour although I have set that active!! Wired.
07-18-2018 21:22
07-18-2018 21:22
I have the same issue. Syncing is a pain. This is my 4th Fitbit and I never experienced anything like this. I've tried different combinations of settings (all day sync, always connected, keep-alive widget, none of the above) and nothing works for more than a few hours. Then I have to do the whole thing of messing with the bluetooth, rebooting the phone, forcing the sync 30 times... Every sync becomes a 40 minute ordeal. I have a Pixel, it's almost 2 years old, so it's not a newly released phone.
Is this issue going to be resolved anytime soon? I still have my old Charge HR and I'm considering abandoning my new Versa in favor of the old device with painless sync.
07-20-2018 07:42
07-20-2018 07:42
I agree, My Versa is several months old and I have not had this issue before this week. Now I can not get it to sync, give notifications of movement breaks, text messages or phone calls. I re booted several times and was able to sync 3 days ago but have not been able to since. I am now in the process of deleting and trying to reconnect my tracker but I am just spinning as it "Connects to Tracker". Not sure why I have had no issues for months then all of a sudden it won't work!
07-20-2018 08:11
07-20-2018 08:11
Did it ever connect? I am stuck in the same place.
So Frustrating!! Heading off on a mountain climbing trip in 30 minutes with no tracker!
08-23-2018 08:09
08-23-2018 08:09
Having exact issue, and it is beyond frustrating. I have gone through the uninstall/reinstall process at least 6 times in the 6 weeks I have had my device. I love the device but at this point am so frustrated I would advise anyone thinking of this device NOT TO BUY. I would think that Fitbit could and should look at what they need to do to resolve such issues.
If I uninstall and reinstall the device, it syncs once. So basically evertime I want to sync I have to uninstall and reinstall the device. UGGGHHH not a good solution or work around.
08-23-2018 11:06
08-23-2018 11:06
08-23-2018 11:20
08-23-2018 11:20
Mine started working perfectly after upgrading to Android 9.
08-27-2018 19:49
08-27-2018 19:49
So many issues with the versa. Had a blaze no problem. Last time it synced on the 20th. I am about to go with the apple watch. So expensive for this versa and not worth it. Then the fitbit app is no help. I am do over fitbit.
08-27-2018 19:52
08-27-2018 19:52
Everything you have listed to do I have done and nothing.
09-04-2018 12:09
09-04-2018 12:09
I have similar issues with my Versa ever since I bought it two months ago, all related to connectivity, in particular for weather app and GPS connectivity reliability to Android phone. Spent hours working on it both alone and with Fitbit support on phone. Ultimately, they admitted they have issues with the weather app and GPS syncing to phone. My two cents... Fitbit knowingly put out a device that they knew had issues with functions they claimed the device had, and we are left holding the stick. They have lost a customer for life.
09-07-2018 05:06
09-07-2018 05:06
My Versa has not synced for three days now. I tried everything on the list. I have IOS. Ready to return it. Any suggestions?
09-07-2018 06:30
09-07-2018 06:30
09-13-2018 02:46
09-13-2018 02:46
I tried with two devices and still the same Bluetooth notification and not syncing or connecting to device.deleted app re set up device and it won’t even register device.
09-13-2018 02:49
09-13-2018 02:49
My phone will syn with the blaze and the one. Not the versa reliably.
09-13-2018 05:28
09-13-2018 05:28
09-13-2018 12:36
09-13-2018 12:36
Good luck hope this one goes ok for u, fingers crossed they find mine faulty and agree to give me a replacement
09-14-2018 06:03
09-14-2018 06:03
Try Garmin. I had a Vivosmaet and liked it a lot but not waterproof. The waterproof ones were just more money than I wanted to pay but in hind sight it might have been a better investment.
