05-23-2018
16:21
10:11
AlejandraFitbit
05-23-2018
16:21
10:11
AlejandraFitbit
I have had my Versa for almost a month now and it has started to have a few issues as follows:
Thank you
Best AnswerI fixed this problem by disconnecting my versa 2 from my phone (for get this device) then reconnecting it. It went through all the steps of connecting to my phone, like when I bought it. So it updated the versa 2 as it connected. So far it has worked. Good luck
Best AnswerYa fitbit is a piece of crap. Spend so much money and its giving me problems over a yr screen not responding, auto restart randomly, heart rate reading go crazy and u name it. As of today 2 of my versa me and my wife both broke down just over a yr.
Best AnswerI dont know if you can help me. But I have the same problem. My touchscreen on the right side does not work after a short swim last night.
This is my second fitbit after a swim before with my first one and had to have it replaced. I do not think mine is waterproof.
Anyway. I have tried several times to hard reset mine using the buttons since I cannot use the settings icon since its on the right side. I used the buttons. I feel like I am following the directions to the letter but am not able to get the "strong vibration" I hold all 3 for 12 seconds, I see the fitbit logo, then when it blinks off I let go of the bottom right button. I continue to hold the upper right and the left button. To no avail the logo continues to blink. I have held it the 8 seconds and other odd amounts of time to see what works. Is there another suggestion?
