04-17-2018 06:59
04-17-2018 06:59
Just wondering if anyone is successfully using the Versa with a Note 8 since it's not on the list of supported devices.
TIA
Best Answer02-08-2019 13:17
02-08-2019 13:17
Best Answer02-08-2019 13:34
02-08-2019 13:34
I went in an reset my settings on my note 8 and it worked!
For anyone else that needs help with this issue.
1st. Make sure versa has been updated to the new firmware.
2nd. Disconnect from bluetooth, delete versa
3rd. Go into your phone settings >general managment > reset all settings to their default.
4th. Go to settings>general management >reset.
5th. Go to settings>notifications>make sure fitbit app and messaging app and email app (email only if you want notifications) set to ALLOW these apps.
Restart versa.
Restart phone.
Connect bluetooth on phone to pair with versa
Go into fitbit app
Click on the versa watch at the top right corner.
Now
Turn on all day sync.
Scroll down....
Turn on Always connected and
Turn on Keep widget alive
Scroll up...
Click on notifications >turn on calls
Go into app notifications make sure, FITbit contacts, messaging apps and emails are all on.
While still in this settings notifications area in the fitbit app,
Go to the top right corner with three dots, click that and click send a test call notification.
Hopefully it works!
If it doesn't, go to the sync in the fitbit app and sync and then try again.
If it does not, you should delete the device and set it up again like a new versa and adjust settings as said above in fitbit app. And the notifications in the phone. Good luck.
*if you turn on do no not disturb, it will make notifications stop.
Best Answer02-08-2019 13:35
02-08-2019 13:35
Restart versa.
Restart phone.
Go into fitbit app
Now
Scroll down....
Scroll up...
Hopefully it works!
Best Answer02-08-2019 13:49
02-08-2019 13:49
Best Answer02-08-2019 14:06
02-08-2019 14:06
Best Answer02-08-2019 14:18
02-08-2019 14:18
02-08-2019 15:15
02-08-2019 15:15
Best Answer02-08-2019 18:30
02-08-2019 18:30
Best Answer02-08-2019 22:56 - edited 02-08-2019 22:56
@Cherylgpepper88 If you have issues with the notifications, please do the following:
As per text notifications and calls on Samsung. Make sure that Preview of the message is enabled - go to your messaging app settings, and enable Preview on the screen. By default, Samsung phones have it disabled, which means message can't be seen on the phone's screen and Versa cannot read it.
Regarding Call Notifications, go to your phone's settings, date and time, and make sure auto-time is turned on. Also, again go to settings on your phone, scroll down to Apps, tap and open Application List. Tap on the three dots in the right top corner, and select Show System Apps. Scroll down through the app list to something like Call Management. This might be called differently on your device. Open it and tap on Notifications. Make sure that Incoming calls are set to Urgent or High.
Best Answer02-14-2019 18:50
02-14-2019 18:50
Were you ever able to make it past the "enter your code" screen? That's where I am stuck... it's been 5+ hours of trying different things, and nothing.
Best Answer02-15-2019 06:58
02-15-2019 06:58
Best Answer02-15-2019 07:04
02-15-2019 07:04
the mileage on my gp0s is all over the place. 0.6 miles for a game of 5 a side for an hour where as my old samsung had me down for 3 miles.
Best Answer02-15-2019 07:06
02-15-2019 07:06
I'll start from the beginning, maybe it'll make more sense lol
I deleted my old fitbit on the app and clicked add new device. I went through the connect to wifi part pretty smoothly (although it didn't find the wifi I wanted to connect to, had to choose my other one). Then I entered the code to pair my fitbit with the app (I believe that is what it was for). It was a 4 digit number. That went smoothly as well. Then it said I had to update. Mind you, not once during this process did my fitbit say anything on the screen other than "install the Fitbit app to begin" in several different languages. So I chose the next step, which was to update. Step 1 of 3. It won't do anything. It just stays on "connecting" for over an hour. I've restarted the Versa. Uninstalled the app and started over. Hooked the fitbit to the computer and tried doing it through the computer instead of the app. Nothing helped.
Whew, that was much longer than I anticipated lol
Best Answer02-15-2019 13:24
02-15-2019 13:24
@Shylo Try performing the whole procedure without adding WIFI first. This will force it to use bluetooth. It will be longer but should complete at least. If you really want to try wifi, perhaps try wifi at your friend's place or work. Make sure Versa is in a charging dock near the router. By near I mean almost on top. eheh
Best Answer02-15-2019 13:37
02-15-2019 13:37
Thank you, I skipped the wifi part and it worked. It took 2.5 hours to complete, but at least it worked lol Thanks again!
Best Answer02-15-2019 14:05
02-15-2019 14:05
@Shylo Awesome news! 😄
Best Answer03-23-2019 06:30
03-23-2019 06:30
I have yet to successfully make this happen. Were you able to get this to work?
Best Answer03-23-2019 07:36
03-23-2019 07:36
Best Answer11-26-2019 17:25
11-26-2019 17:25
How do I connect my note 8 to my fitbit watch
Best Answer02-19-2020 09:36
02-19-2020 09:36
I usually check for compatibility before buying things and I could have swore I looked this up before we purchased them. Mine worked flawless for 9 months, but now won't connect or sync no matter what I do. (I have done all the uninstalls, reboots, restarts, turn off, turn on's suggestions) with no joy. I even tried different versions of old software. Funny, my wife has the SAME EXACT PHONE and the same exact fitbit (Versa) which were bought the same exact time. She has no problems. I just did a random google search for stores selling it and they all seem to say roughly the same thing. For example, Nordstrom has this below:
- Compatible with Mac OS X 10.6 and up, iPhone 4S+, iPad 3 gen.+, Android 4.3+ and Windows 10 devices
I also checked the box for the Versa and it only says "Requires iPhone, Android or Windows". See picture below as proof.
If you go to https://www.fitbit.com/DEVICES and put in Samsung Note 8, as the screenshot below indicates, all the features are compatible PER FITBIT.
