04-26-2018 07:13
04-26-2018 07:13
It seems my Versa is working as it should functionally however it wont stay connected to Bluetooth long enough to fully sync, update apps, receive notifications, etc... In the fitbit app under my account it will say "looking..." for a while then "connected..." for a second, then "syncing..." for a second then just go back to "looking...". So i went to my iPhone Bluetooth settings and can see that it connects for a second or two then just disappears, then connects and disappears and continues the cycle. Anyone else having this specific problem? Any suggestions to fix it? I've restarted the app, uninstalled it, reinstalled it, turned my bluetooth on and off, restarted my phone, restarted the Versa. Nothing seems to work.
10-06-2018 10:33
10-06-2018 10:33
I cannot get my versa to sync either. Terribly disappointed in the product. Have had a fitbit since 2015, was so excited to upgrade. Won't sync and battery life is super short, about 3 days. Have tried everything suggested in these threads, all different devices, get error messages that my fitbit has Bluetooth issues. Ready to give up and find a different brand.
10-06-2018 11:28
10-06-2018 11:28
10-11-2018 09:02
10-11-2018 09:02
Having the same exact problem. This is my second replacement
10-13-2018 22:31
10-13-2018 22:31
@Tiggernut57 are you on Android or iPhone. iPhone is pretty stable. Android not so much. Also it seems Fitbit mobile app version matters. My experience says anything above 2.74 is a complete akhem... sorry Fitbit but it's the truth. I've never downgraded so many times. I hope and hope that each update will resolve the issues but nopes. I'm back to version 2.74. yay. My most treasured file. 😑
10-14-2018 20:40
10-14-2018 20:40
10-15-2018 16:11
10-15-2018 16:11
I’m on iPhone and it’s still not staying connected even after restarting twice! 😏
10-15-2018 21:39
10-15-2018 21:39
Me also facing same problem Versa not connecting with my Android One+3T. But data getting updated after sync up with Apple 5C. Eache and every time I have to sync Apple 1st and Android getting updated.
10-16-2018 21:57
10-16-2018 21:57
@Uthamaraj I'm on OP3T. It does work but is not stable all the time. Also forget newest version of the Fitbit mobile app. I cannot use anything higher than 2.74 or versa won't stay connected. PM me if you have additional questions.
10-17-2018 06:52
10-17-2018 06:52
10-17-2018 20:23 - edited 10-17-2018 20:26
@RonS16 pretty much. I believe 2.74.2 worked slightly better for me. Had both versions (2.74.1 and .2) at one point but they were hogging the space so left only 2.74.2. Try .1 and see how it goes. 2.74.2 is flying somewhere around on a**mirror probably. Mind you I still have to perform magic tricks (kill the bluetooth, shut off the versa, and/or forget versa) from time to time, but at least it's working. More or less...
10-25-2018 07:40
10-25-2018 07:40
This worked for me!
11-02-2018 11:31
11-02-2018 11:31
Same exact problem. I’m on my fourth replacement from Fitbit. At this point they won’t refund my money and the store I bought it from won’t take it back. Complete waste of $200. Can’t believe this company won’t make this right. Basically taking money for a product that doesn’t work. Obviously this comment thread shows that this isn’t an isolated issue.
11-02-2018 11:33
11-02-2018 11:33
@Bsfrode I guess it's because not the hardware issue but software. May I ask which Fitbit OS version are you running .15 or .19, and what about Fitbit mobile app version?
11-02-2018 11:45
11-02-2018 11:45
Where can I find that information?
11-02-2018 11:50
11-02-2018 11:50
@Bsfrode On your versa, go to Settings app, then scroll down to About, version number should be on top. In the Fitbit mobile app, tap on the Account icon (Top right corner next to your Versa icon) and scroll down to Help. Tap it, version number should be on top.
11-02-2018 11:54
11-02-2018 11:54
.15 on watch and 2.82 on mobile app
11-02-2018 12:01 - edited 11-02-2018 12:01
@Bsfrode Are you on Android (if yes, which one? Oreo or Pie? And what's the phone model) or iPhone? Also, has any of your versa trackers ever synced with your phone?
11-02-2018 12:30
11-02-2018 12:30
iPhone. Yes they have right at first and then progressively get worse. Eventually syncing sporadically and then not at all.
11-02-2018 13:09
11-02-2018 13:09
@Bsfrode I must admit I am a bit surprised that it's an iPhone. I'm saying that because iPhone is my fallback on phone. When I cannot sync my Versa with my droid I use iPhone to "unclog" it. I tried both iPhone 7 and my husband's iPhone XS Max. Mind you I have no idea if the versa stays connected long enough. At this point, I can only suggest clean install. Unlinking versa from the account, forgetting versa from bluetooth settings, uninstalling the Fitbit app, formatting versa to wipe it clean, resetting iPhone to factory defaults, and finally installing Fitbit app and setting up Fitbit Versa again, granting all the permissions it wants.
11-02-2018 13:35
11-02-2018 13:35
Thank you for the input. I’ve tried all of those options with each unit. Doesn’t seem to help. I think I’m the proud owner of an expensive brick at this point.
