04-15-2018 00:30
04-15-2018 00:30
I’ve had my versa since Thursday, during the day my watch will work fine and sync with no issues. When I get up the following morning it will no longer sync, Bluetooth connection keeps dropping (only when trying to sync). I factory reset Friday morning and Saturday morning, spent over a hour each morning installing and setting the watch up again. I’ve spent longer trying to get my watch to work instead of using it. I’ve tried everything, phone on/off, Fitbit on/off, delete and reinstall app, Bluetooth on/off. Other than factory reset I can’t see anything else that works! Very upset and disappointed
08-06-2018 00:52
08-06-2018 00:52
08-07-2018 09:24
08-07-2018 09:24
Hello everyone, I hope you're all doing well.
I appreciate your participation in the forums and for sharing your experience with us. If your Versa is still having trouble syncing, please restart it by pressing and holding the Back and Select buttons (left and bottom right) until you see the Fitbit logo on the screen. I understand some of you have already tried some troubleshooting steps, but for those of you who haven't, please try the following:
I would like to suggest you to check the following:
If your device still won't sync, try these steps:
Additionally, I would like to recommend you to enable All-day Sync so your Versa can maintain a constant communication with the Fitbit app on your phone as long as Bluetooth is on. Please note that it has been confirmed that All-day Sync will not drain the battery on your Versa or your phone faster than usual.
To set up All-day Sync go to Account > Versa, then scroll down until you see the option to enable it.
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
08-07-2018 09:57
08-07-2018 09:57
Thank you for your sage advice. All of those technical suggestions were tried and were unsuccessful. The update is, I received my replacement last week and this one does not hold a charge. Third one shipped out yesterday.
08-07-2018 10:01
08-07-2018 10:01
My Husband got a Versa in July and no matter what he does or how many times he does it, nothing work to get it to stay connected to the app. I told him to call support but he says there are so many with the problem that they should fix it soon. He is so upset with Fitbit now that after buying 6 different Fitbits through the years, he says no more never again. It has been too long now for him to get a replacement or his money back. I hope that the powers to be in Fitbit can find out what is wrong with all the Versas.
08-07-2018 10:14
08-07-2018 10:14
Marco, if you read through this discussion you'll soon see that a lot of us have been through all that already. Some people have done it multiple times. There is something wrong with a lot of Versas.
How about this? Since the defective Versas are Fitbit's problem, Fitbit should take responsibility for fixing them. Now. No more trying to push the solution off on the Versa owners.
08-07-2018 10:17
08-07-2018 10:17
This is the second versa I have owned. the First one just shut off suddenly a few months after owning it. I sent it back and fedex lost it. After waiting two weeks for them to acknowledge the device was lost I Finally got my replacement. It will not sync however, except maybe once a week after I have fiddled with it for hours doing ALL The troubleshooting. Nothing suggested in this thread has worked, and I will NOT remove all my bluetooth devices in order to get this to sync. That should not be necessary. I will not remove everything else from my life because one thing won't work. The only proper solution in this regard is to remove the thing that is not working, which I am seriously considering. But seeing as I paid nearly $300 for it, It will not be easy.
08-07-2018 10:17
08-07-2018 10:17
btw did anyone notice that in 99% of my cases where my fitbit won't sync there is more then 10 minutes difference in the time on the Versa and the time on my phone?
08-07-2018 10:21
08-07-2018 10:21
08-07-2018 10:26
08-07-2018 10:26
08-07-2018 10:27
08-07-2018 10:27
I was finally able to connect it after restarting my phone.... again this should not be necessary every time I try to sync the device, which it appears to be. The excuse 'well you finally got it to sync didn't you, case closed' does nothing for the effort I had to go through to get it to sync. I am wasting hours trying to get this device to work the way it should work automatically.
08-07-2018 10:29
08-07-2018 10:29
I have tried that multiple times.... it worked once..... I Had to disconnect the device, uninstall the app, reinstall it, restart my phone, and then it would finally reconnect. All this troubleshooting for a toy is ridiculous.
08-07-2018 12:35
08-07-2018 12:35
08-07-2018 12:42
08-07-2018 12:42
I kept my ALta HR and I use it as a backup which has been pretty much everyday fo the past four weeks. They did replace mine and the battery won’t hold a charge on this one. Another replacement coming now so I will update when this one arrives and I can test it. It is quite frustrating (especially after buying replacement bands for the Versa). I hope you get a suitable resolution!
08-07-2018 13:00
08-07-2018 13:00
I continue to do all this and have since I got my Versa a few weeks ago. I've had a number of other Fitbits and there was no issue with syncing with any of them. I have a Samsung S7 and this is getting to be very frustrating.
08-07-2018 18:27
08-07-2018 18:27
I tried it all the versus sucks
08-07-2018 18:41
08-07-2018 18:41
yes it does. Go apple or garmin just saying.
08-07-2018 23:08
08-07-2018 23:08
08-08-2018 14:37
08-08-2018 14:37
It’s not working for me as well I have tried everything
08-09-2018 03:55
08-09-2018 03:55
After upgrading from the Charge 2 to the Versa it worked great all day but stopped syncing overnight. Restarts, on & off wouldn't fix it. All day sync and all those settings were on.
However, when I switched the device icon I noticed it was still recently syncing with the old Charge in the drawer. I think whenever I was near the Charge it connected to that and wouldn't find the Versa. After deleting the Charge it connected to the Versa.
So maybe Fitbit only reliably supports having one device added.
Hope that helps someone.
08-09-2018 07:06
08-09-2018 07:06
Worked Perfect! Thank you!
