04-16-2018
18:41
16:50
AlessFitbit
04-16-2018
18:41
16:50
AlessFitbit
My versa isn't vibrating or telling me when i get a call or text. When i pull down they are there but i want the notification.
02-15-2019 11:25
02-15-2019 11:25
You are very welcome
02-18-2019 06:01
02-18-2019 06:01
Brilliant! This worked for me. I must have held that button down and unknown to me turned vibration off! It’s now back on.
02-21-2019 07:05
02-21-2019 07:05
That was it!!! Thank you so much
02-22-2019 07:48
02-23-2019 07:51
02-23-2019 07:51
That's IT!!!
Excellent
I was wondering for days what was going on, turns out my kids had been playing with it and turned off notifications from watch! Hold left button, swipe left and it's right there!
Thank you!!
02-23-2019 08:30
02-23-2019 08:30
Hope you are doing great, @Ed-baby! I appreciate the update. 🙂
As you mentioned, those are the steps to turn on/off the notifications on your Versa. So I appreciate you have shared them here in the thread.
Please feel free to share any other comment or question. I'll be glad to help you out!
03-02-2019 09:03 - last edited on 10-06-2019 14:06 by LiliyaFitbit
I am having the same problem. My text, phone, etc notification function (vibration) is not working. They all worked for several weeks and suddenly stopped for no reason that I can discern. I read and followed the suggestions described in this chain and still nothing. Please note that my Fitbit had to be replaced recently because the battery on the one I purchased more or less died.
Moderator edit: format
03-02-2019 09:19
03-02-2019 09:19
Ok, I spoke to Fitbit and they had mentioned to restart the Fitbit. And that worked. And now it works fine.
Try that. See if that works.
Because mine did stop working also, and I did chat with Fitbit and they mentioned to me to do that. And now it works great.
So try that. Hope this helps.
03-02-2019 19:33
03-02-2019 19:33
03-06-2019 22:28
03-06-2019 22:28
Tristan, you are a legend! I must have accidentally done this, probably in my sleep! I hadn't realised how much I miss my vibration notices until they were gone and you have brought them back! Thank you so much! 😊
03-13-2019 17:38
03-13-2019 17:38
Easy fix!
Simply press and hold the back button until the "screen wake" or "music controls" screen pops up and press "notifications" to ON.
This accidentally gets pressed and turned off sometimes! Same issue happens periodically to me.
03-16-2019 08:48
03-16-2019 08:48
This tip was the ONE! After trying everything else suggested, holding down the left button until “notifications” came up was the fix. It was “off” even though it was showing “on” everywhere else....even on my phone app! I hope this works for others also! Thanks!
03-16-2019 23:45
03-16-2019 23:45
03-18-2019 07:00
03-18-2019 07:00
I must have hit the button on the left hand side as a user stated. I checked that and the notifications were off. This worked after turning them back on.
03-18-2019 20:52
03-18-2019 20:52
This worked for me! Thx!
03-19-2019 14:54
03-19-2019 14:54
Hold down the left button until a menu pops up and make sure the notifications aren’t turned off. Same thing happened to me. I tried everything people recommended. Finally, I called because nothing worked. It was that simple.
03-21-2019 13:20
03-21-2019 13:20
THANK YOU!
feel so stupid but this simple step worked for me...
I changed my straps the other day and must have switched it off by accident!
03-21-2019 13:32
03-21-2019 13:32
03-22-2019 12:44
03-22-2019 12:44
and the real answer is: it's the left single button on your versa. hold it in a couple of times and you will see option to turn vib on or off.
03-27-2019 12:19
03-27-2019 12:19
Thank you! I didn’t know this was a thing. Just checked this function and it showed me notifications were off despite my checking and turning it on in the settings.
