07-03-2023
09:57
16:46
LizzyFitbit
07-03-2023
09:57
16:46
LizzyFitbit
Voice replies to text aren't working since switching from Fitbit account to Google account. I have a Versa 2. Any ideas?
Moderator Edit: Clarified subject and updated label
08-07-2023 16:36
08-07-2023 16:36
Hi everyone!
Thanks for your comments, and your patience throughout this process.
If you haven't done so, let me recommend updating the Fitbit app to the latest version. This should resolve the issues with the transcription error displayed when using voice replies on your Fitbit Smartwatches. To do this:
Once you've installed the update, please confirm if the voice replies start working again on your watch.
07-03-2023 19:35
07-03-2023 21:10
07-03-2023 21:10
Its 2023 and we are having the same issues guess they dont know how to fix things
07-04-2023 23:11
07-04-2023 23:11
Having the same issue .. frustrating
07-08-2023 05:45
07-08-2023 05:45
Have you found a fix for this?
07-09-2023 07:21
07-09-2023 07:21
07-09-2023 18:58
07-09-2023 18:58
Mine has stopped working also. It's frustrating because this is why I got the watch to be honest. Now I am unable to use it and considering another brand.
07-11-2023 10:00
07-11-2023 10:00
This has not been resolved as I bought the versa 2 and versa 3 literally 2 days ago and both gave me this transcription error from the beginning. I've reset both watches 3x and still no difference. If this issue cannot be resolved permanently I really won't buy another fitbit watch again. Please help me to fix this
07-11-2023 10:31
07-11-2023 10:31
About a year ago(?) this happened to me and after several rebooting of my phone and Fitbit Versa 2 - it finally got solved by Fitbit - I would suggest you call them . Good luck - I know it is very frustarating
Best Answer07-11-2023 10:37
07-11-2023 10:37
Thanks Joey will do that
Best Answer07-11-2023 11:05
07-11-2023 11:05
Team, I bought my versa 3 last week. Voice reply is not working.
This is the main feature that I wanted to buy this watch, now it's not working.
I called support and tried all the possibilities that support people told me, still not working.
Can you Help and let me k ow what needs be done to get this feature work ?
Reboot app and phone
Voice reply :on
Bluetooth : on
Notification:on
Microphone on watch : on
Wife setup : done
07-11-2023 13:02
07-11-2023 13:02
This is now the 8th time restarting the entire process and still no luck. These watches should be recalled as issue appears to be constant across several models. I've now already tried versa 2 and 3 and same issue keeps flagging. I really want this fixed but don't know how. @Fitbit please help
07-11-2023 13:09
07-11-2023 13:09
I think there is a year warranty - ask for a new one - this is not acceptable
07-13-2023
14:30
10:08
07-13-2023
14:30
10:08
Since i transferred to google account my voice reply is not working. Keeps coming up with an error. Was on chat for over an hour installing, ininstalling etc still wont work.
07-13-2023 23:38
07-13-2023 23:38
Best Answer07-14-2023 04:53
07-14-2023 04:53
Hi @Penneyp - this is a known issue with the Google account and there is nothing you can do. See Transcription problem
Best Answer07-14-2023 07:50
07-14-2023 07:50
Best Answer07-15-2023 10:38
07-15-2023 10:38
Since the switch ro the Fitbit Google app my microphone does not work on my Versa 2. I have tried numerous solutions with no luck. Any ideas?
Best Answer07-15-2023 11:26
07-15-2023 11:26
I didn't get a update but I am still suddenly having the same transcription error.
07-15-2023 19:19
07-15-2023 19:19
Hi @RobinH710 - if you switched to using the Google login there is a known issue. You may see transcription error.
If this is not the issue go to the watch Settings and make sure the microphone is on.
