My dilemma right now is that I have an Adidas SmartRun hooked into their MiCoach platform. I can go on there and download the training plan to the SmartRun Watch via wifi, it tells me the HR zones I need to be in during the run via audio prompting (speed up, slow down) as well as audio feedback for pace, distance, etc and I can listen to MP3s stored on the device via bluetooth. They are end of lifing the program at the end of 2018 and I'm trying to find a viable alternative.
Ideally, this would be the best case scenario for the Ionic:
1.) Goto Fitbit App/Website and Select a Half/Full Marathon Training Plan based on Current Fitness level or anticipate goal for completion
2.) Select Quantity of Days per week to Run and Long Run Day
3.) Sync with the Ionic and it will tell you your future runs including intensity and duration
4.) Sync Music to the Ionic
5.) Go for a run (either treadmill or gps outdoors)
6.) Listen to music and hear audio prompts via bluetooth headphones during the run. The prompts would be linked to current heartrate or pace and telling you to speed up or slow down.
7.) Periodic updates during the run at mile markers. Mile 3, pace: 9:17, HR 142, Time... Etc
8.) Finish run and see results and how well you adhered to the program
Moderator edit: label.
This is a simple challenge that has already been solved by Adidas 4 YEARS AGO! They are killing the program though and nobody has been able to fill this void.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
