06-07-2021 17:46 - edited 06-28-2021 11:19
Hi there,
Our team has released the new Fitbit iOS App 3.43 version and it should be available for all of you. Please make sure to download it from the App store as this will resolve the battery short life issues experienced on your Sense. Take in mind that this and future Fitbit app versions will require iOS 13.4+.
Hi everyone. Thanks for your continued reports.
Our team is aware of the Sense not holding charge when syncing with iOS devices and they're working to bring a fix as soon as possible. In the meantime, we recommend force quitting the Fitbit app on your iOS devices to prevent the battery from draining when syncing.
I've moved your posts to this thread so we can keep our team informed of this situation. Your patience is truly appreciated and please know your feedback hasn't gone unnoticed.
See you around.
06-13-2021 01:27
06-13-2021 01:27
@LizzyFitbit Hello. You still have not replied to my easy question. Has the issue with the breathing rate data fixed with the new firmware? It's just a yes/no answer, not rocket science.
06-13-2021 05:17
06-13-2021 05:17
It’s June 13 and this draining of the battery continues. Appears that this issue first came up in early May. Why has this issue not been fixed yet. It started with the download of the new devise software.
06-13-2021 05:30
06-13-2021 05:30
So after updating to 3.43, removing apps, SPO2, changing clock face, my battery is holding. Although the latter is a good thing, the fact that I can’t use desired features is not. Also, GPS and/or exercise tracker is not working. I go for a run or walk and about 5 minutes in, the exercise shuts down, watch goes dark and seems to need to reset itself.
06-13-2021 08:09 - edited 06-13-2021 08:10
I'm having the exact same issue and this is beyond frustrating. I've reset to factory and reinstalled the app, but nothing seems to work? This WAS a great watch (I've owned different fitbit models for over a decade). I installed the new update yesterday and last night I went to bed with the battery at over 90 and woke up 7 hour later and the watch was dead. I don't want to have to read through thousands of posts to find the fix. Could someone from FITBIT please reach out to us all who are having this issue?
06-13-2021 08:34
06-13-2021 08:34
06-13-2021 12:13
06-13-2021 12:13
Here is a BETTER FIX that worked for me, as the Fitbit moderator’s recommendation is failing me: On my iPhone, I go to Settings, and scroll all the way down to the Fitbit app and click it. There is a setting for Bluetooth. Disable it. This disables just the Fitbit app’s access to Bluetooth instead of all Bluetooth for the phone. Seems to be working well so far. I just have to remember to enable this setting again when I want to sync data, and then disable again after syncing so my sense battery doesn’t die. Of course, this is a temporary band aid fix until Fitbit is able to fix the actual source of the problem…hopefully…soon…Fitbit team… please… this is super annoying.
Background and other things I tried…
I was procrastinating but finally updated my Fitbit Sense a few days ago and immediately began observing the battery drain issue being discussed in this thread.
I tried the recommended fix of force quitting the Fitbit app per the iOS instructions every time I use the app but my sense is still dying by 2am over night.
I tried removing the sense from the Fitbit app, but this is a pain in the butt to have to set it up again from scratch when I want to sync data.
Turning off Bluetooth on my iPhone fixes the battery drain problem but I use Bluetooth for other things so this is not ideal.
Hope this was helpful…
06-13-2021 12:55
06-13-2021 12:55
06-13-2021 13:44
06-13-2021 13:44
06-13-2021 16:03
06-13-2021 16:03
Yes, have done the factory reset, removed and reinstalled the app on my phone with no luck. I've now turned off bluetooth for the app (as mentioned by @ToniBeanMango ). Hopefully something will work. Its frustrating that a watch that would reliably hold a charge for about 4 - 5 days, doesn't last through the night. This last step of turning off bluetooth for the app hopefully is a short term fix as they need to address what the problem is.
06-13-2021 16:15
06-13-2021 16:15
Updated w/version 3.43 on Fitbit app. After a long day of running around & fitting in a workout, I ended the day w/4% battery drain on my Sense leaving me @ 96%. Syncing was fine. I was pleasantly surprised as I didn't have app up on my phone, and I had my bluetooth on. I don't want to say my Sense is back to normal, that remains to be seen in the coming days - I don't want to jinx it.
I'll keep checking this thread for any new issues and updates....or if I start having problems again.
06-13-2021 16:18
06-13-2021 16:18
It is weird the factory reset seems to work for some and not others. I can’t believe Fitbit can release software that isn’t tested properly to avoid these issues. I know Apple wouldn’t do this and also know from recent experience that their customer relations people are so much better. I’m now willing to forgive the battery life of an Apple Watch as at least I know what to expect from them!
06-13-2021 16:37
06-13-2021 16:37
I’m having this issue since the iOS update doesn’t last the day. I’ve turned off all apps and syncing but just drains. Hopefully this issue will be fixed soon I’m paying for premium and not even getting the standard product at the moment. I’m assuming there will be some refunds applicable while this issue is being sorted. Thanks Ange
06-13-2021 20:11
06-13-2021 20:11
I've had same issue. Very frustrating!
06-14-2021 00:11
06-14-2021 00:11
Same sync/battery drain issues. Been a loyal FitBit user for years but the this and not being able to listen to music while out exercising is testing that. Father’s day next weekend, is it time to go for an Apple Watch?
06-14-2021 00:25
06-14-2021 00:25
06-14-2021 01:31
06-14-2021 01:31
06-14-2021 01:58
06-14-2021 01:58
Same here.. Fitbit is aware of this and not doing anything about it ..just fibbing us off with riding fixes ..when there is a obviously a hardware problem
06-14-2021 05:40
06-14-2021 05:40
I have not really had any issues and owned this watch since October 2020. That’s what’s weird to me. Everyone complains about software issues. One would think if software were the problem wouldn’t everyone be impacted?
06-14-2021 06:10
06-14-2021 06:10
06-14-2021 07:35
06-14-2021 07:35
