06-03-2016 11:50 - edited 06-23-2016 18:57
Version: 34.5.14
Silent Alarms: None
Music Control: None
All-Day Sync: Off
Quick View: Off
Notifications: 2 -- Call and Text Notifications.
I rarely get phone calls or texts.
I only synch my Surge 3 times a day.
I may swipe the screen 6 times a day, if that.
Yet I only get about 6 hours of battery life from it: it dies in my sleep, which is an inconvenience. One of the reasons why I got the Surge was to monitor my sleep.
I have had it for about a year, and I used to get 3 days from a charge.
What is the expected life of a Surge? Is there anything else I can do to extend the battery life?
06-03-2016 11:59
06-03-2016 11:59
I have had my surge for six weeks. If I'm lucky, i get 24 hours from a charge. any activity that uses the GPS kills it even more quickly (i was aware that GPS use shortens battery life). FitBit, what do you recommend ?
Version: 34.5.14
Silent Alarms: 2
Music Control: None
All-Day Sync: Off
Quick View: Off
Notifications: Off
06-03-2016 20:32
06-03-2016 20:32
Best Answer06-03-2016 22:45
06-03-2016 22:45
Best Answer06-17-2016 10:02
06-17-2016 10:02
Hello guys @AlanWright, @SunsetUser and @Whereissilijili hope you are doin' great! I can see you have tried several steps to make the battery of your Surge last longer, however there are some other tips that I would like you to take a look of on @MarreFitbit post.
Try them and let me know!
Best Answer06-17-2016 13:04
06-17-2016 13:04
Hi @HeydyF - I logged a call with support, they confirmed my Surge had a faulty battery and have since replaced it FOC. I have now had the replacement four days so far and battery life is much better. Thanks for the follow up - Al.
06-17-2016 22:25
06-17-2016 22:25
06-18-2016 05:10
06-18-2016 05:10
Awesome @AlanWright! I knew that Fitbit Support will help you out with this and get you back on track with your new tracker.
@PJS70 So you already contacted Fitbit Support, right? can you please tell me the response you received from them?
Keep me posted guys!
Best Answer06-18-2016 06:31
06-18-2016 06:31
Best Answer06-23-2016 18:53
06-23-2016 18:53
E-mailed Tech Support.
Did what the same silly things mentioned above.
Tech Support gave up and sent me a new Surge.
Problem solved ... for now.
06-23-2016 18:56
06-23-2016 18:56
Tried them. Didn't work. My life revolves around charging the Surge since it only lasts for 6 hours.
Emailed Tech Support. They agreed that the Surge is a dud. They sent me a new one.
Nothing else helped.
06-23-2016 19:04
06-23-2016 19:04
@PJS70
I just contacted Tech Support, and they sent me a replacement.
"Thank you for troubleshooting the Fitbit Surge tracker¨s battery issue with us. We can assist you with the Fitbit Surge tracker¨s warranty.
"We can see in the account that the battery is lasting about 8 hours, these kind of issues are all covered by our warranty.
"Please note that this is not a normal behavior of our trackers and we'd like to help you live up the true Fitbit experience by providing you with a complimentary replacement.
"We appreciate that you're a Fitbit member, and we want nothing more than to help you solve the issue you're experiencing with your Fitbit Charge HR tracker, so you can continue to reach your goals."
06-23-2016 20:31
06-23-2016 20:31
Hmmm, interesting. So Fitbit can see the battery life data. Good to know.
Mine is new, less than a month old, and I can already see that if I go for a long bicycle ride, the battery will give out before my sixty-five-year-old body does. Not a good sign. The engineers of all this new technology don't seem to appreciate or understand how we use this stuff. The only battery powered stuff that lasts as long as I need it are my flashlights and old transistor radio. Everything else needs to be recharged about an hour before I need a nap.
06-25-2016
11:07
05:29
06-25-2016
11:07
05:29
Hi @SunsetUser sounds awesome that Customer Support helped you out with this, and sent you a new Fitbit Surge to get you back on track!
@DougLourey I really appreciate your feedback in regards to improve the battery life of the trackers. I'm truly sorry to hear about your Surge battery issues as Fitbit products are durable and long lasting and should not have become defective at an early stage and this applies for all of our Fitbit trackers.
Let me know if you need anything else guys!
06-25-2016 14:36
06-25-2016 14:36
07-09-2016 21:43
07-09-2016 21:43
Interesting, they offered a 25% discount to purchase a new Fitbit product when I contacted them for a dying battery after 12 hours and turning off all the features also. My Surge was past the 1 year warranty period.
Best Answer07-19-2016 15:31
07-19-2016 15:31
07-19-2016 16:40
07-19-2016 16:40
This device needs a 'user replaceable battery.' And there needs to be an option for installing a longer-life battery. I can't wear mine all-day-long because it needs to be recharged too often. So how valuable are the Dashboard reports on my daily activity? They're not.
It's designed like a wristwatch, but functions more like a stopwatch; something you use while at the track working out. When mine starts acting up, I'm just gonna throw it into my kitchen junk drawer. I won't be buying another one either, so it's just a fad to me.
Best Answer07-19-2016 16:49
07-19-2016 16:49
07-24-2016 06:02
07-24-2016 06:02
