This does not work!!
Revoke numerous times, still does not sync, is there another solution??
Best AnswerThey just did a update and the whole group was having trouble are leader said they were working to resolve it but worked for me and changed my email as well
Best Answerapparently ww is "working on this" two years later.
Best AnswerDid you ever get a fix for this?
Best AnswerUnfortunately this did not work for me. I disconnected all, multiple times. Rebooted. Used the website through a computer instead of the apps. Any other suggestions? When I try to sync it, the WW app just asks me to make sure my Fitbit app is up to date, which it is. Thoughts?
Best AnswerThis was my problem ALONG time ago. It turned out to be a weight watcher problem and yes they fixed it
Best AnswerMy solution was to wait for Weight Watchers to figure out it was their problem. It took a day or 2 if I remember correctly.
Best AnswerAlso, I noticed that on the weight watchers web site (can’t see it in the app) that a wireless scale was trying to connect to a Fitbit which was ‘overriding’ the connection to my Fitbit fitness device. When I disconnected the wireless scale, voila, it connected to my Fitbit and my activity points start to show in my WW app.
Best AnswerI have done this procedure on my Weight Watchers ap. No luck. It synced once but not since. I’ve disconnected and reconnected again and still shows zero steps when I was over 10,000.
Best AnswerI tried this and it did not work.
Best AnswerI am having the same problem. My Fitbit has stopped syncing with my WW app. I did as you said and revoked the access in Fitbit for WW and now it does not give me the option to reinstate it. Please help.
No, this isn't a solution. It doesn't fix the problem. The problem is a communication issue with
Best AnswerThis isn't a solution and is barely a bandaid. Tried this and it still has communication problems. The fix needs to be between the apps. Not a restart, redo, uninstall, reinstall, revoke...all useless as the communication issues still exists. What are the developers doing to fix this. Otherwise they really aren't compatible.
