11-30-2015 11:50 - last edited on 12-01-2015 08:05 by AngelaMa
Has stopped syncing with weight watchers tracker.
06-12-2016 15:39
06-12-2016 15:39
06-12-2016 17:18
06-12-2016 17:18
06-12-2016 18:28
06-12-2016 18:28
Hello..I have revoked access to the WW app from fitbit and now I am not able to relink the two back up again..Since I revoked access my steps are not being recognized on the Weight watchers site..How do I link them back up so it is showing on fitbit website?
06-16-2016 08:52
06-16-2016 08:52
Hello @sweetred are you still experiencing issues with the WW integration. If you are I would suggest to do the following:
1. On the Weight Watchers homepage click Login.
2. Confirm your Weight Watchers user name and password and click Log In.
3. Click the profile icon in the top right corner and then click Settings
4. Click the Activity tab and click Connect to a device or app.
5. Select Fitbit from the choices and click Continue.
6. Log in using your Fitbit account credentials.
7. Once logged in, you will be redirected back to the Weight Watchers Settings page.
You can confirm both accounts have been linked on your profile settings, under Applications. If after this you are having issues syncing let me know more details about your experience so I can further investigate. @Chris-m thanks for your cooperation.
I'll be around if you have any questions! 🙂
It is health that is real wealth and not pieces of silver and gold! Share your story!
06-16-2016 11:08
06-16-2016 11:08
I have the same problem. I've contacted WW and Fitbit and know one seems to know how to resolve this issue.
06-16-2016 11:10
06-16-2016 11:10
The problem is that it does not go to the Fitbit to allow you to log into your Fitbit account. That's the step that is missing and no one can answer why it isn't working.
06-30-2016 08:30
06-30-2016 08:30
I was having this same issue and was thinking that it was not synced up. I would suggest that once your WW app is showing that you have connected your Fit bit to then check your fit points. It should show your steps from your fitbit and give you a point value.
07-01-2016 04:30
07-01-2016 04:30
Welcome to the Fitbit Community @Josefit06 and @debz916! It's great to have you here 🙂 @debz916 where you able to connect your accounts? @Josefit06 thanks for your cooperation.
07-01-2016 07:06
07-01-2016 07:06
07-04-2016 19:16
07-04-2016 19:16
Recharge the FitBit Battery. I will stop syncing before it is really dead
07-07-2016 05:27
07-07-2016 05:27
Hello @sweetred it's great to know your Fitbit is syncing! 😉 @DanCapone thanks for stopping by.
I'll be around if you have any questions.
08-22-2016 15:39
08-22-2016 15:39
I haven't been able to get it to sync despite trying EVERYTHING. This is the message I get:
Synced with your Fitbit app on Wed, 4 Mar, 2015 10:47 AM
Well that's a year and a half ago - hardly relevant.
I'm a huge fitbit fan, but the lack of cooperation and resolution is making me more than a little disgruntled. Surely your IT department can talk to their IT department and work it out.
09-14-2016 11:11
09-14-2016 11:11
Disconnect the Fitbit and reconnect - but be sure you disconnect in two places!
Settings ACTIVITY -
Settings WEIGHT -
Once you disconnect both places - it will ask you for your fitbit credentials again!!
09-25-2016 10:40
09-25-2016 10:40
this is actually a WW issue not fitbit
01-12-2017 17:31
01-12-2017 17:31
Weight watchers is utterly useless for any type of tech support!
01-31-2017 22:10
01-31-2017 22:10
Even from my computer, it won't let me disconnect
Could it be because it is also an apple product?
02-22-2017 17:47
02-22-2017 17:47
it just told me weight watchers was not availabe for my device
03-18-2017 16:40
03-18-2017 16:40
This worked for me! Thank you!
07-11-2017 07:58
07-11-2017 07:58
I agree. I spent over 2 hours on Chat with WW with 2 different people and got no where. I was very angry.
09-07-2017 07:17
09-07-2017 07:17
I have revoked access however it is now no longer letting me connect the two and keeps saying error500, any ideas?
