11-30-2015 11:50 - last edited on 12-01-2015 08:05 by AngelaMa
Has stopped syncing with weight watchers tracker.
03-09-2016 04:14
03-09-2016 04:14
03-10-2016 05:42
03-10-2016 05:42
Hello @chastaga, @JeannetteP and @DesWo hope you are having a very active day! @DesWo thanks for sharing the troubleshoot 🙂 @chastaga let me know if this helps!
Keep me posted!
It is health that is real wealth and not pieces of silver and gold! Share your story!
03-22-2016 13:54
03-22-2016 13:54
03-24-2016 07:11
03-24-2016 07:11
Hello @Wandaj727 welcome to the Fitbit Community! I'm glad to hear the troubleshoot provided on this thread was useful and your accounts are syncing 🙂
Hope to see you around more often 😉
04-06-2016 19:38 - edited 04-06-2016 20:01
I'm having trouble syncing the fitbit too. Can you tell me how to manually put in steps? When I look it give me the option to log time but not steps for walking. If I add steps it shows like stair steps which is different. Thanks. Renee
Update: Nevermind I think I figured it out. I used steps even though the icon looks like stairs.
04-07-2016 03:19
04-07-2016 03:19
04-07-2016 05:45
04-07-2016 05:45
Hello @Majesty1919 and @Wandaj727! 🙂 @Majesty1919 I'm glad to know you figure out how to add the activity, if you have any question about manually adding activities review this post. @Wandaj727 thanks for your cooperation!
Happy stepping! 🙂
04-07-2016 05:53
04-07-2016 05:53
04-08-2016 04:31
04-08-2016 04:31
Hello @Chris-m, is your tracker not syncing to your account? Is it only syncing calories to MFP? have you tried the troubleshoot provided here ?
04-19-2016 12:00
04-19-2016 12:00
04-19-2016 14:21
04-19-2016 14:21
Right. I tried all of these. I think it was the website because all of a sudden it started syncing almost instantaneously and I've had little problems at all since.
04-19-2016 17:17
04-19-2016 17:17
Hi all!
I am new to fitbit and WW. I have been trying to sync my fitbit to the WW app and website. The only way it syncs is when I disconnect and reconnect. I have tried to revoke and re connect, I have also tried to uninstall all apps and reinstall. I also contacted WW chat and they were no help. Any more suggestions?
04-19-2016 17:54 - edited 04-19-2016 17:57
Ashley,
You did the most common things I'd suggest. The only other one is to reset the fitbit itself.
Plug your charging cable into your computer.
Plug your Fitbit One™ tracker into the charging cable, making sure that the gold contacts on your tracker align with the gold contacts in the inside of the charger.
Hold down your tracker's button for 10-12 seconds.
Remove your tracker from the charging cable and press its button until the screen turns on.
Lastly, sometimes it can be the WW site but I've not been having trouble over the past few days.
04-21-2016 05:23
04-21-2016 05:23
Hello @Majesty1919, @Ashley82802 and @Chris-m, It's great to have you here! 😉 @Chris-m I'm glad to hear the restart worked! @Majesty1919 Thanks for your cooperation! 🙂 @Ashley82802 welcome to the Fitbit Community! Let me know how it goes with the restart suggested by @Majesty1919
Thanks for stopping by, see you around!
04-24-2016 16:42
04-24-2016 16:42
My fitbit one won't sync to Weight Watchers since yesterday. It won't work on the app or the website. Does the one not work on Weight Watchers anymore? I've tried deleting both apps and reinstalling them, disconnecting and reconnecting the fitbit to WW.
04-24-2016 19:45
04-24-2016 19:45
04-25-2016 06:04
04-25-2016 06:04
Hello @gadawg84 welcome to the Fitbit Community! @SunsetRunner It's great to have you here 🙂 First make sure your tracker is syncing with your account. If it is and you already did the procedure advised here and here please contact WW support for assistance.
Catch you later! 🙂
04-25-2016 18:45
04-25-2016 18:45
04-26-2016 04:48
04-26-2016 04:48
Hello @gadawg84 I'm sorry to hear that thanks for sharing the update.
Hope to see you around more often!
06-12-2016 15:34
06-12-2016 15:34
I revoked WW and now I can't reinstall it back to my fitbit and it is not syncing at all now??? Can someone tell me how to link them back up again? I
