11-30-2015
11:50
08:05
AngelaMa
11-30-2015
11:50
08:05
AngelaMa
Has stopped syncing with weight watchers tracker.
Best Answer06-05-2019 11:45
06-05-2019 11:45
FWIW, I'm having the same problem. I was able to get a synch to happen once by disconnecting and reconnecting, but I'm loathe to do that multiple times in case I can't reconnect.
This worked for the longest time. Something has changed.
Fitbit Flex
Weight Watchers in browser.
Best Answer06-05-2019 12:00
06-05-2019 12:00
Best Answer06-05-2019 13:49
06-05-2019 13:49
Best Answer06-05-2019 14:19
06-05-2019 14:19
My WW app and FitBit aren't syncing now either. They worked the past few weeks, then just stopped. I was able to "disconnect" the FitBit and reconnect them the past couple days, but now I can't Disconnect at all, I just get an error message (500). I went onto the FitBit site and Revoked access to the WW app (per a suggestion on the FitBit site). I wonder if that is the problem? If so, I can't find a way to give permissions back to WW. Ugh, so frustrating!
06-05-2019 14:41
06-05-2019 14:41
Best Answer06-05-2019 15:59
06-05-2019 15:59
My fitbit aria scale stopped syncing with WW yesterday. I went into the fitbit to revoke access and now I can't get the link back to sync with WW. I contacted WW and they said this is a known problem over the last couple of days and they are working on it but don't have a fix yet and not sure when they will get it. i am very frustrated that they did not send out a notification to users. It was only my scale that was not syncing - my activity was syncing. But now, because I revoked access I am getting nothing.
Best Answer06-11-2019 10:47
06-11-2019 10:47
Hello everyone!
I apologize for the delay in my response. Thanks for sharing all of those details and explaining the situation
In this case I'd like to ask if the situation has continued or if it has been working correctly now?
I look forward to your reply.
Best Answer06-12-2019 09:02
06-12-2019 09:02
This is still an issue for me and has been for over a week. I've followed all the steps here with no success. the last sync with my Fitbit on the WW app is June 4, even though it's been disconnected & reconnected. Really seems to be a WW app issue but I don't know what steps they're taking to fix it.
Best Answer06-12-2019 09:46
06-12-2019 09:46
My syncing issue seems to have been resolved. Thanks for the follow up.
dawn
Best Answer06-12-2019 09:52
06-12-2019 09:52
Best Answer06-12-2019 10:03
06-12-2019 10:03
Best Answer06-12-2019 11:30
06-12-2019 11:30
Like others, things.... just started working again. Yay!
Thanks for the follow up!
Best Answer06-13-2019 06:57
06-13-2019 06:57
Hi - my Aria scale is syncing with weight watchers and so are the steps from Fitbit - but the activity minutes are not populating in Weight Watchers.
I spoke to someone in tech support at WW and they said they will be phasing out the integration with Fitbit - because there are so many problems. Do you know anything about this?
Best Answer06-17-2019 09:23
06-17-2019 09:23
Hi everyone. Thank you for your updates regarding the integration and hope it keeps working for the ones who posted a favorable resolution.
@maurmal I haven't heard anything like this. Do you have any official notification from them? I don't think this is happening? Did they tell you via Support or do they have any official post on their website?
Best Answer06-18-2019 06:05
06-18-2019 06:05
Hello - I called their tech support last week because my activity minutes were not syncing with WW - prior to last week nothing was syncing (weight from aria weigh scales and steps from fitbit charge2). The activity minutes are now syncing this week so everything is back to normal.
The tech support person on the call told me that weight watchers would be phasing out (??? - how do you phase this out) the syncing between weight watchers and fitbit because there were too many problems with it. So, it was an unofficial source at best. And there was nothing on their website.
Wonder if there is any way to confirm this?
Best Answer01-21-2020 10:49
01-21-2020 10:49
This worked for me thank you
Best Answer01-22-2020 02:27
01-22-2020 02:27
7813330208 chat me on WhatsApp
Best Answer04-18-2020 17:07
04-18-2020 17:07
What worked for you? I’m having the same problem. Just joined WW and was hoping the Fitbit sync would be easy like the Fitbit app, but it is not pulling up my steps/ activity. Says I have 0 steps when I definitely have more.
Best Answer04-19-2020 03:18
04-19-2020 03:18
Best Answer04-19-2020 04:00
04-19-2020 04:00
Ah okay, wish that worked on mine but it still isn't 😞
Thank you though!
