10-25-2017 17:50 - edited 03-21-2018 10:22
I've been notified that there are reports of Zip battery draining quickly on iOS version 2.41.1 and our team is currently investigating. If you are experiencing this, we recommend disabling all-day-sync for now. I'll update this post once I hear more. Thanks as always for your patience and understanding.
Turn off All-Day Sync:
Actively managing your weight? Find accountability buddies on the Manage Weight board
03-17-2018 00:48
03-17-2018 00:48
03-18-2018 04:31
03-18-2018 04:31
03-21-2018 10:20
03-21-2018 10:20
Hi Everyone - it has taken the team longer to identify the root cause of why some users are experiencing rapid battery drain with while syncing the Zip to an iOS device. We will continue to investigate, but I don't currently have a timeline for fix. Along with turning off all day sync, we do suggest syncing to a computer or Android device if possible. Thanks for your reports and patience.
03-21-2018 12:25
03-21-2018 12:25
03-21-2018 12:28
03-21-2018 12:28
03-21-2018 13:29
03-21-2018 13:29
@DeeSchu that's good news, thanks for sharing
@Trisha66 it looks like you had a case back in December addressing this. You can follow up on that email, or if you like I can create another case for you.
03-21-2018 13:50
03-21-2018 13:50
I have always synced to a computer and yet still go through at least a battery a week.
03-21-2018 14:43
03-21-2018 14:43
@gweb if you are using Fitbit Connect I don't think this issue should affect you, even on a Mac. Is the battery properly aligned, as mentioned in this post?
03-21-2018 15:15
03-21-2018 15:15
03-25-2018 17:39
03-25-2018 17:39
I have been running into this for the past 6 to 8 months and it is getting to be quite an annoyance. I am about ready to give up on using a zip and the iOS app. I haven’t had the all day sync on at all during that time. It seems that I am changing the battery every month and even when I change it the iOS app shows it half depleted within a week of changing it.
03-25-2018 18:30
03-25-2018 18:30
03-26-2018 02:58
03-26-2018 02:58
Thanks. I assume that means you are no longer synching your Zip to your iPhone; only to your computer. Is that correct? What's weird is that my Zip doesn't show a low battery; only the iPhone app. Sometimes it actually drops to red indicating battery depleted, but my zip indicates a full battery. I think there is actually a problem with the battery indicator connection between the zip and the IOS app.
03-26-2018 05:53
03-26-2018 05:53
03-26-2018 08:04
03-26-2018 08:04
I have had my new Zip, the replacement they sent me, for 11 days.
The battery is still full, knock on wood, and All Day Sych is off.
I don’t sync on my computer but when I tap it to wake it it syncs.
I check through the App on my iPad.
03-27-2018 14:38
03-27-2018 14:38
Hey there @JaneAZ, @debleo, @SunsetRunner, and @caroljj53! Thanks for all your feedback and your patience with the issue you are experiencing. As stated above by @KateFitbit if you are not using the an iOS device, and you are experiencing any difficulty with your battery make sure to follow the suggested workaround here.
If you are using an iOS device, double check that you have All Day Syncing disabled. As suggested in the main post here. Or, in the meantime you can use an alternative compatible Android device or computer to sync.
03-27-2018 17:08
03-27-2018 17:08
i find that my Surface, Zip and phone always have something different for the battery life. I don't get it and it's pretty annoying that Fitbit can't figure this out
03-28-2018 05:47
03-28-2018 05:47
Durham, NC
03-28-2018 07:29 - last edited on 04-03-2018 13:29 by LucyAP
Am replying to this post to agree with and address a number of issues raised on this forum:
-- The IOS app explanation (excuse?) seems inappropriate to me. I have similar issues syncing with my Windows 10 PC (sometimes the battery icon indicates low charge, sometimes not and sometimes the icon is correct and sometimes it isn't). Also, I have no plans to haul my Dell All-in-One PC with me on vacation to track my hiking steps so that I can earn rewards through a health program I'm participating in.
-- If you scan other Fitbit product forums, you will see that the battery and syncing problems are shared with the Charge, Alta and One even though they may have different types of batteries and charging systems from the Zip. Not so much with the Flex.
-- The suggestion to play with the spring in the Zip battery case to ensure it is properly seated is a joke. I was told to pull it out (didn't help) and see that others were told to push it in (apparently also didn't help).
-- While there may, indeed, be an incompatibility between the IOS app and updates and Fitbit products, it behooves Fitbit to either develop a workaround NOW or stop marketing their products as compatible with iPhones.
Moderator edit: format
03-28-2018 07:41 - last edited on 04-03-2018 13:31 by LucyAP
This post is 100% on point. It is time for Fitbit to step-up and correct the problems or state that it does not work with iOS products. Great Post!
03-28-2018 15:23
03-28-2018 15:23
I'm finding that my Zip battery isn't draining, it's just not reading the charge properly. It goes from half full to empty and back to full again on a regular basis. FYI.
