10-25-2017 17:50 - edited 03-21-2018 10:22
I've been notified that there are reports of Zip battery draining quickly on iOS version 2.41.1 and our team is currently investigating. If you are experiencing this, we recommend disabling all-day-sync for now. I'll update this post once I hear more. Thanks as always for your patience and understanding.
Turn off All-Day Sync:
Actively managing your weight? Find accountability buddies on the Manage Weight board
03-28-2018 15:39
03-28-2018 15:39
this is the exact same issue i'm having.
03-28-2018 15:48
03-28-2018 15:48
03-29-2018 10:04
03-29-2018 10:04
03-30-2018
04:51
13:32
LucyAP
03-30-2018
04:51
13:32
LucyAP
I put a Brand New Battery in my Zip last night because all of a sudden, it went from full charge to no charge on the device itself (the IOS app was still at half charge since it hadn't synced since that time). Once the new battery was in and the device synced with the app, all looked good. This morning the device and the app showed full charge. Now, all of a sudden, the device is still at full charge (at least it isn't displaying the half charge or no charge icon) and the IOS app shows half charge. Really!? Not even 24 hours with a new battery . . .
Moderator edit: format
03-30-2018 08:41
03-30-2018 08:41
04-03-2018 13:49
04-03-2018 13:49
Hey there! Thanks everyone for your comments regarding the issue you are experiencing. We are really sorry for the inconvenience, and we hope to get you back on track soon.
At the moment, if you are using an iOS device the best option is to follow the suggestions on this post. Or, to use an alternative compatible Android device or computer to sync.
If you are using an Android or Windows device, and you followed the suggested workaround here with no avail please let me know so I can be of help.
04-03-2018 14:14
04-03-2018 14:14
04-03-2018 16:36
04-03-2018 16:36
04-03-2018 16:50
04-03-2018 16:50
04-04-2018 11:14
04-04-2018 11:14
Dear Fitbit
I have had some success with turning off all day sync, but my last battery only lasted one week. It was a high quality (read that as expensive) battery. It is so frustrating that you put no effort into your customers. I have a Zip and a Blaze. It's not an insignificant investment and all I want is to not have to spend so much on batteries and not to lose days of activity. Seriously, can't you do better.
04-05-2018 16:56
04-05-2018 16:56
Hi everyone! Thanks for sharing your input about this. Rest assured that we are taking all your feedback in to consideration and we hope to get you back on track soon.
We'd like to share with you that our engineering team is still working to solve this as soon as possible. In the meantime, I'd like to kindly suggest you to turn off the All Day Sync feature. To disable All Day Sync on your app. You need to go to account, then tap the picture of your tracker and scroll down and disable this option.
04-05-2018 17:53
04-05-2018 17:53
04-05-2018 18:27
04-05-2018 18:27
04-05-2018 20:05
04-05-2018 20:05
I hate to burst the bubble here but I was sent my new Zip in early March, after complaining to the company. I have been using it since March 15 and the battery is still full.
I had only had my Zip for a few months which is why they sent me a new one....plus I was insistent and annoyed.
04-05-2018 20:52
04-05-2018 20:52
04-06-2018 03:17
04-06-2018 03:17
04-06-2018 08:44
04-06-2018 08:44
Lucy:
Who is on the team resolving this How many people, working how many hours, reporting what to whom, what has been resolved so far? Advising manually synching your phone or bending the battery connection up or down for almost 6 months hardly validates your comment that Fitbit is diligently working on this.
04-06-2018 08:53
04-06-2018 08:53
04-06-2018 11:28
04-06-2018 11:28
This only works some of the time. It makes no sense, but I have been following this suggestion for months. Sometimes a battery will last 1-2 months. My last new battery lasted 1 week. 1 week! Jeez.
04-06-2018 11:38
04-06-2018 11:38
