07-30-2020
23:04
19:01
07-30-2020
23:04
19:01
I was reading in this community and find it strangely odd that several people had their Alta HR all die at the same time. Does someone know something I don't know? Thanks.
08-06-2020 09:26
08-06-2020 09:26
I am having the same issue. Every two days I need to charge my Fitbit which stinks as I am trying to use it with friends and work on challenges and step goals too. Has anyone received any help from support@fitbit? Wondering if we need to ask them to replace it. Given so many people are having this issue it seems like an update setting or something went wrong and is effecting users.
Best Answer08-06-2020 09:57
08-06-2020 09:57
Doubt they would replace them. From what I understand, they no longer make the Alta HR
08-06-2020 11:49
08-06-2020 11:49
My Alta HR started to scroll through its readouts erratically then eventually stopped working (around mid-July 2020). Now it won’t charge at all.
08-06-2020 11:54
08-06-2020 11:54
08-06-2020 11:54
08-06-2020 11:54
12:01
07:10
08-06-2020
12:01
07:10
Hello everyone.
I am sorry to hear about your unresponsive Alta HR devices. Not sure what the cause of your issues may be. It could be the display not working or the battery not charging or not holding a charge. If you haven't tried any troubleshoots then you can try the following:
Clean the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves.
You can follow these instructions to help improve the battery life and these instructions to help your device charge.
If you want you can also reach out to our Support team (click here to contact them) for further assistance. This is why I have created tickets for you @HVKiesling @HannahRobinson7 @hamcar @Grandmalainie @criley14 @Walker51 .
Please keep in mind that Support does follow the guidelines described in the warranty so if your device is outside the warranty period they won't be able to replace it. This is why some got offered a discount, to help them in case they would like to keep using a Fitbit device. Still thank you for sharing your feedback.
Let me know how it goes.
Best Answer08-06-2020 12:25
08-06-2020 12:25
Hello Alvaro.
Isn't it the least concerning to Fitbit that so many people began experiencing the SAME issues at the SAME time, considering their devices were bought at different times?
My battery, when fully charged would last 7 days. Then starting Tuesday, it now barely lasts 3-4 hours.
That usually means a recent software/firmware or app update is causing these issues.
Many here are prepared to leave Fitbit and move to another brand of activity tracker. If you truly care about your customers, you would contact your technical team to research.
08-06-2020 12:40
08-06-2020 12:40
Thank you for your message. My issue is that all of a sudden my Alta will not hold a charge for longer than 8hrs. Once charged it seems to work well. As my first Fitbit did the same (was replaced as still under warranty) I have always been careful not to o overcharge it and to clean the contacts periodically as prescribed. I am not sure there is anything anyone can do.
I am disappointed as I love the Fitbit Alta HR and am sorry that it looks as it's days are numbered.
08-06-2020 12:42
08-06-2020 12:55
08-06-2020 12:55
Same here Galaxy Samsung S9. Did an update few days before and Fitbit completely went dead. Bought TWO new chargers will not even charge. SO NOW 10 bands, 3 chargers and a dead FITBIT!! They offered 25 percent only for a short period of time. Not sure what I will do at this point but I do miss a tracker on my wrist to let me know how I'm doing.
08-06-2020 13:05
08-06-2020 13:05
You made out better than most. It was 25% a couple of days ago. Glad you got more. I agree we all should really get a lot more than that.
08-06-2020 13:11
08-06-2020 13:11
Hello Alvaro:
This is just not right to do this to people. YOU KNOW good and well this was done intentionally to have so many fitbit ALTA HR's go down within the same timeframe. Some were under warranty and some were not. I do hope you relay ALL these messages from UNHAPPY customers. I used to love your products now I question your policies and procedures. Makes one think twice about moving on from FITBIT for sure.
08-06-2020 13:15
08-06-2020 13:15
I'm a Samsung Galaxy phone guy. Looking seriously at one of the Galaxy watches. But I don't need all those bells and whistles. Just want steps, distance, and something that syncs with my WW app.
It's against my principles, but I may give the Fitbit Inspire a try. Only $60 without HR monitor. But Fitbit has really lost my respect
08-06-2020 13:17
08-06-2020 13:17
I don’t know if you saw a previous comment of mine, but, fit bit has just been bought out by google. I don’t know how that would tie in to all the Alta HR’s going down but they must think we’re a bunch of idiots. I wonder if they read the community posts.
08-06-2020 13:49
08-06-2020 13:49
Best Answer08-06-2020 14:42
08-06-2020 14:42
Thanks for your help! 👍I’ll get in touch with them.
Best Answer08-06-2020 15:41
08-06-2020 15:41
I’ve had the same issue, only it was late July
Best Answer08-06-2020 19:16
08-06-2020 19:16
08-09-2020 11:27
08-09-2020 11:27
This is a software update issue, I am hoping that if enough people report it and cause a stir that maybe Fitbit will fix it. I have a feeling that they are trying to get all of us that were on this model into a newer, more expensive model. There is no way that everyone in this thread had an issue at the same time for it not to be caused by a software update.
08-09-2020 11:27
08-09-2020 11:27
