03-12-2016
09:46
14:27
ErickFitbit
03-12-2016
09:46
14:27
ErickFitbit
My fitbit app wouldn't work with my new Samsung Galaxy S7 (Marshmellow) due to syncing issues. I just reset my fitbit (plug it into laptop/wall charger and hold button on left side for approx 10seconds until fitbit symbol appears, then unplug it). App worked instantly! 🙂
Moderator edit: edited title for clarity
09-21-2016 04:37 - edited 09-21-2016 04:38
Well your personal preference with all respect has nothing to do with the issue that the s7 can't be used as a tracker.
When someone is asking why the issue hasn't been resolved half a year later, and your response is that we should all just buy another fitbit device or use a different tracking platform cause you personally hate to carry your phone with you, all you are doing is poking a beehive.
If Fitbit is going to enable some phones to work as trackers, then they should keep software up to date enough to support all mainstream best selling brands.
09-21-2016 05:11
09-21-2016 05:11
09-21-2016 05:13
09-21-2016 05:13
So you were able to use the phone as a tracker? If so please list the steps on how you achieved this.
09-21-2016 05:25
09-21-2016 05:25
09-21-2016
05:32
08:25
RobertoME
09-21-2016
05:32
08:25
RobertoME
When I say as a tracker...
I mean *specifically* no other fitbit device wearable involved!
I don't care if it links with computer or reports to the mobile app then
shoots off the data.
I just don't want to buy another fitbit wearable.
Other than that I don't care how my phone gets the data to the fitbit
dashboard.
Moderator Edit: Removed Personal Information
09-21-2016 06:49
09-21-2016 06:49
09-21-2016 07:06
09-21-2016 07:06
Sorry for the delay in updating. Firstly, my fitbit was previously syncing with my S7 when it suddenly stopped in the middle of the day. I tried all of the fixes, uninstalling and reinstalling the app, unpairing the device with my phone (which then would not pair back), and restarting the fitbit with the paper clip method. I contacted support, and they were not terrible helpful, mentioning that the device is not supported...etc. but that they were looking into it. I finally had success once I let the fitbit completely die. Magically I was able to get a bluetooth signal from it, and it paired with my S7. I was able to reset it up, and it has been back with no problems since. That said, I don't know if it was the fact that the device got a total reset from draining, or if something was done at the support level. Anyway. Good luck guys, I don't understand why all of this is going on, but Fitbit almost lost me to Samsung Gear (and I really didn't want to do that).
09-21-2016 07:19
09-21-2016 07:19
09-21-2016 08:48
09-21-2016 08:48
Hi everyone and welcome aboard@SAR1L, also thank you for your updates and participation @Marissa3209, @Diamend100.
Note that whit this devices that are high end, specially Samsung is not that are not compatible if is not on the list of supported devices. It means that has not being fully tested to guarantee it will work flawlessly or wont present any difficulty at the moment to sync for example. I have to refer back to my friend @ErickFitbit's post. I know its been a while since this thread has been running, but regard this matter we don't have specific dates that we can share as moderators regard when the devices are tested and updated to our list.
@SAR1L what you are looking by reading your post is to use your phone as a replacements of your tracker, unfortunately the only feature that can do this is MobileTrack. Which is a feature only available for selected devices that at the moment is not available for Samsung models.
Also as an additional note this is a Community where users share their own experiences and ideas in order to help other users. So let's keep a friendly environment and everybody is welcome to share opinions and feedback. For additional information please refer to our Community Guidelines.
See you around.
09-22-2016 07:29
09-22-2016 07:29
Pretty frustrating. Just got a Samsung S7 Edge. My fitbit Charge HR worked at first, then stopped. Looking online I can't believe how long this has been an unresolved issue. To not be able to sync after this long after the release of a major cellphone platform - wow - lack of interest on fitbits part. Mine is now in a drawer. Keep in mind to keep the fitbit family of products off upcoming holiday lists - wouldn't want to give a present that represents out of date technology.
09-23-2016 04:53
09-23-2016 04:53
09-23-2016 06:15 - edited 09-23-2016 06:16
I synced my Charge HR to the Fitbit app on my S7 Edge just fine this morning. However, Verizon just sent out a system update that is downloading and installing now. Afterwards, I will check and see if my Charge can still sync with the Fitbit app on my phone. I will post after I check.
09-23-2016 06:18
09-23-2016 06:18
09-23-2016 06:40
09-23-2016 06:40
System update is complete. My Charge HR synced to the app just fine.
09-23-2016 06:55
09-23-2016 06:55
To SAR1L:
I have spoken with Samsung about being able to use the S7 as a tracker for Fitbit. They do not want to do that because they have a competing fitness program, S Health, that they want you to use instead of Fitbit. This is a Samsung issue, not a Fitbit issue. So basically your options are use S Health as your fitness program to use your S7 as a tracker or purchase a Fitbit tracker and install the Fitbit app on your phone if you want to use Fitbit as your program.
09-24-2016 10:35
09-24-2016 10:35
This post was made back in March. Any reason why the Samsung S7 is still not available?
09-24-2016 15:15
09-24-2016 15:15
To All,
Thanks for the tips and comments.
I was not able to sync theSurge and the S7 Edge unless it was through wifi. Nor was I able to receive any notifications. I went through the troubleshooting tips posted earlier with no avail.
But, there apparently has been a Fitbit patch last week. Upon opening the Fitbit app, it asked me whether I wanted to update (even though auto-updating is toggled 'on'). I selected 'Yes', it downloaded, and started up similar to install a new device. It now syncs without wifi AND I receive text and phone notifications. All is good 🙂
Oddly, the S7 is not on the list of supported devices.
09-26-2016 06:36 - edited 09-26-2016 06:37
The issue isn't the syncing or the general use of the app/watch. That all works fine. It's just that the Blaze should work like the Apple watch where you can preview text messages and phone calls - that part is not supported with the S7. It is with the 3, the 4, the 5, and even the 6 and everything else under it. Super annoying!
09-28-2016 13:24
09-28-2016 13:24
This was dated in March. Any updates yet?
09-28-2016 13:37
09-28-2016 13:37
