09-18-2017 14:20
09-18-2017 14:20
I have had my Fitbit blaze for at least a year. My battery does not hold a charge for what is told that it does. What do I do for this ? Will Fitbit replace my blaze or replace and fix my battery?? Please let me know !
Thanks !
09-19-2017 13:23
09-19-2017 13:23
It's great to have you here @Lizkoenig! Currently, it's not possible to change the tracker's battery. However, the resolution will be taken based in the Fitbit Warranty.
I would like you to double check you've restarted your Blaze. Also, make sure you're charging it properly. Here are some tips to improve your tracker's battery life.
Hope this helps!
09-20-2017 03:53
09-20-2017 03:53
09-21-2017 16:38
09-21-2017 16:38
Thanks for letting me know that you've done the troubleshoot posted above @Lizkoenig! Customer Support will review each case individually and provide you with a solution always based in the Fitbit Warranty.
I've shared your post with Customer Service, they should reply to you within the following days.
Hope this helps!
01-04-2019 18:48
01-04-2019 18:48
I have the same issue. Blaze has 2 years now and the battery will not last one day....please help!
01-05-2019 09:23
01-05-2019 09:23
Hi im having the same issue - any advice appreciated
01-05-2019 13:18 - last edited on 01-12-2019 16:53 by FerdinandFitbit
Hm, I think it's a goner. Sometimes restarting or resetting it sets things straight. The Blaze was discontinued some time back, but they are still selling them in stores. If you are past the product warranty period, then they may not get back to you. Contact them, and see what they can do for you. It's worth a shot. https://contact.fitbit.com Take a short vid of what it's doing or not doing.
Moderator edit: Format
01-06-2019 16:26
01-06-2019 16:26
Don’t know if this will help but if it’s out of warranty and chucked in drawer u got nothing to lose
was given blaze by my son battery would last 3 hours max so tried it for day or two he was right so ordered new battery off internet so put it on charge got to about 60% and thought bugger it chucked it in the freezer for about 30 mins when I took it out the temperature icon was on the screen so put it on charge anyway when it was fully charged I switched off the heart rate monitor and synced it this was on the Wednesday night I’m writing this and it’s sunday and it’s still got half battery and I wear it all day only for steps but it’s going strong just going to see how long it lasts still got hr monitor switched off though
01-07-2019 04:44
01-07-2019 04:44
01-08-2019 17:28 - last edited on 01-12-2019 16:53 by FerdinandFitbit
I didn't know one could swap out the battery, nice one!
01-09-2019 00:12
01-09-2019 00:12
01-09-2019 01:11
01-09-2019 01:11
Wow, that was good thinking on your part.
01-09-2019 01:30
01-09-2019 01:30
01-09-2019 01:44 - last edited on 01-12-2019 16:54 by FerdinandFitbit
Well, you tried. Hopefully, that new battery, when it arrives will help with the issue. If your product is still under warranty, (within the first year of use) they may exchange it for you. It would be painstaking for you to go out of your way to buy another battery to then realize it's another problem. Hopefully, you can return the battery if in fact is isn't the solution you hoped for. Something tells me that it is the battery which is a bit weird seeing that these units are supposed to be brand new. Hope it works out just fine.
01-09-2019 01:48
01-09-2019 01:48
01-12-2019 17:04
01-12-2019 17:04
Hi everyone! Good to see you in the Fitbit Community Forums! 🙂
I'm sorry to hear that you're having problems with the battery on your Blaze trackers not lasting as it should. I'd like to help you out.
@fcamillo @SunsetRunner,I've escalated your case to our Support Team for them to help you out with this. Please, keep an eye on your inbox for more instructions and if you need more help, feel free to let me know!
If anyone else needs help with this, feel free to tag me and I'll be happy to help!
01-12-2019 17:22
01-12-2019 17:22
My battery was slowly dwindling. Lasted about a full day, then last night out of no where on a full charge, it died in under an hour. Is anyone else having problems with it just dropping like this? Also I’ve had it for two years, so the warranty is probably up. But I need a new battery. I’ve tried the freezer, but it doesn’t make it more than two hours. Where do you guys order new batteries?
01-13-2019 05:28
01-13-2019 05:28
Ordered mine off eBay haven’t turned up yet though and it’s not a case of just installing a battery it needs to be soldered in so you will need someone who’s handy to do it
01-13-2019 09:49
01-13-2019 09:49
01-13-2019 13:05
01-13-2019 13:05
Did you guys even tried to contact the Fitbit Support Team? I did and they solved my problem with a replacement. 🤷:male_sign:
