10-17-2017
08:55
06:06
AlejandraFitbit
10-17-2017
08:55
06:06
AlejandraFitbit
Is the Fitbit Blaze compatible with the Samsung Galaxy 28 Edge Plus having a nightmare connecting via Bluetooth.
A warm welcome to the Community @Rhinos4573.
Samsung Galaxy S8 Plus, is a compatible mobile device. You can check this information here. If you are having issues connecting it with your tracker, I recommend taking a look at the Having trouble syncing? post and follow the instructions provided there.
Let me know the outcome. ![]()
Best AnswerThey claim it's compatible, but six months later it's barely syncing, eating up battery life like crazy and not sending notifications. If you haven't bought it yet, I wouldn't. Here's just a small selection of posts about it.
https://community.fitbit.com/t5/Blaze/Battery-drain-Samsung-Galaxy-S8-S8-Notifications/td-p/2215923
https://community.fitbit.com/t5/Android-App/No-notifications-through-Samsung-Galaxy-S8/td-p/2249794
Best AnswerJust bought a Blaze and it will not pair with my S8. I've tried every solution on earth, online and at Fitbit and it still won't pair with anything but Classic. "Pairing rejected by Blaze" is the message. Apparently it won't send notifications if only paired in Classic. Nice device but without all the features, useless for the price. I see this all over the Forums. What gives? Can't Fitbit make this work? And please, don't tell me to go through all the steps listed in these help Foeums. I've spent hours going through them over and over and over again.
Note: My Surge worked just perfect for over a year. It's paired both in Classic and standard pairing.
