02-16-2018 09:50 - last edited on 09-08-2020 18:54 by MatthewFitbit
Hi, for the past 3 days my charge 2 has not been syncing to my android device. I have tried force stopping the app, turning Bluetooth on and off, I have turned my phone on and off and uninstalled the app and it still is not working. I do not know what else to do please can someone help?
Thanks, Jane
02-18-2018 06:21 - edited 02-18-2018 11:41
I'm not sure which phone is being used, I find with android, removing the tracker from the Bluetooth menu, not the Fitbit app,, or clearing the Fitbit apps cache helpful.
02-17-2018 04:33
02-17-2018 04:33
Hey @JBARRIE, let me give you a warm welcome to the Community! I appreciate the time you have taken to try to fix this issue. Since it persists, there is something else that I'd like you to do. Could you please restart your Charge 2? Just follow the instructions below to do so:
1. Plug the charging cable into the USB port on your computer or any UL-certified USB wall charger.
2. Clip the other end of the charging cable to the port on the back of the tracker. The pins on the charging cable must lock securely with the port.
3. Make sure the button on your tracker is aligned with the button opening on the charging cable. You'll know the connection is secure when the tracker vibrates and you see a battery icon on your tracker's display. Your Charge 2 will begin charging.
4. Press and hold the button on your tracker for four seconds. When you see the Fitbit logo and the tracker vibrates, this means the tracker has restarted.
5. Unplug your tracker from the charging cable.
In addition, I would like you to review that you have the most updated version of the Fitbit app installed on your phone.
Then try to force sync your tracker.
Let me know how it goes!
03-17-2018 06:55
03-17-2018 06:55
I had the same problem - it worked for me. An additional problem - my charge 2 did not record any sleep for me last night. First time I had that problem.
03-17-2018 08:18
03-17-2018 08:18
I tried this but my fitbit does not show the logo. Nothing happens when I hold the button.
03-17-2018 10:35
03-17-2018 10:35
Hubby having the same problem. Won't sync to his phone. Done the restart several times. Mine works just fine.
03-19-2018 06:48
03-19-2018 06:48
Hey @SJBK, I hope you are doin' great! Just to confirm, is it your Charge 2 syncing fine now?
Now regarding your sleep, could you please tell me, are the sleep stages that are not being tracked or any of your sleep data?
@Calliesmom, it is great to see new faces around! Have you made sure that your computer is ON while trying to restart your Charge 2, right?
@RuthW15, sounds pretty cool that your Charge 2 is syncing fine. If you have further questions, let me know. 😉
Keep me posted guys!
03-19-2018 10:21
03-19-2018 10:21
Mine is fine hubbys still won't connect to honor 7x. Any ideas?
03-19-2018 18:33
03-19-2018 18:33
The only thing I can think of is, check your blue tooth. Make sure that his tracker is the only one listed. Also be sure the blue tooth is on. Sometimes mine turns off for no apparent reason
Good luck.
03-19-2018 19:15
03-19-2018 19:15
03-19-2018 19:26
03-19-2018 19:26
Great news. We just have to keep trying different things, until we hit the right one. Glad you found the answer.
03-24-2018 12:26
03-24-2018 12:26
Hey guys! I hope you are doin' great!
@RuthW15, please keep in mind that the Huawei Honor 7X isn't on the compatible devices list so that could be the main reason why is giving you syncing issues. However, I'd like you to try to turn on/off the Bluetooth on his phone and then reboot the phone.
@Calliesmom, sounds good that your Charge 2 is syncing now. Thanks for the update!
@SJBK, I appreciate your participation my friend!
Have a nice day guys!
03-26-2018 07:46
03-26-2018 07:46
Just have had my Charge 2 for over a month; my very first Fitbit. I purchased it after finding out from friends which one is their favorite. I have had no issues until last night...did not log any sleep. It's fully charged and iPhone synced. Did all shown in this thread to no avail. The sleep tracker is one of the main reasons I purchased this particular model and have loved the details it provides. Now, what next? It is a Fitbit firmware issue/outage?
03-26-2018 08:23
03-26-2018 08:23
Have tried everything, Charge 2 will not sync to my new iphone 8.
Have reinstalled app on phone. Have reset the fitbit a couple times.
Continues to say searching.... on iphone. So frustrating
03-27-2018 12:33
03-27-2018 12:33
Hey @RHornsby1, welcome to the Community! Sounds very cool that you are enjoying your new Charge 2. Let me ask you this, regarding the sleep, is it not tracking your sleep stages or is it not tracking any of your sleep at all? Has this ever happened to you before? In the meantime, let me suggest you the following:
- Manually sync your Charge 2. See instructions in How do Fitbit trackers sync their data?
- Try to sleep with the tracker on your non dominant hand
- If those steps won't work, please manually log your sleep to reflect the time slept. See instructions in How do I change my sleep history?
@swilliams25, welcome to the Community! Thanks for trying to restart your Charge 2 and reinstalled the app on your iPhone to try to fix these syncing issues. Since the issue persists, I'd like you to review this article which has syncing instructions for all the platforms.
Let me know how it goes folks!
03-27-2018 13:50
03-27-2018 13:50
Did not work for me. Have any more idesa?
03-27-2018 14:53 - edited 03-27-2018 14:53
03-28-2018 10:15
03-28-2018 10:15
03-28-2018 10:15
03-28-2018 10:15
That is what I had to do. Thanks
03-28-2018 13:55
03-28-2018 13:55
Hello all, and I thank you for the responses! It’s working fine again; I did the reset 3 times and it worked last night. Here’s hoping that was the one time glitch! Thanks again!
