02-16-2018
09:50
18:54
02-16-2018
09:50
18:54
Hi, for the past 3 days my charge 2 has not been syncing to my android device. I have tried force stopping the app, turning Bluetooth on and off, I have turned my phone on and off and uninstalled the app and it still is not working. I do not know what else to do please can someone help?
Thanks, Jane
03-30-2018 08:38
03-30-2018 08:38
Hey @lmangum, I hope you are doin' great! So, is it your Charge 2 syncing fine now? If so, did the tip that @Rich_Laue posted, helped you out?
Welcome aboard @RHornsby1, thanks for the update my friend! Sounds pretty awesome that your Charge 2 is syncing as expected now!
Keep me posted guys!
04-21-2018 14:44
04-21-2018 14:44
Thank you. I have carried out your instructions and my Fitbit is now OK.
Best Answer04-21-2018 21:53
04-21-2018 21:53
I am having the same problem. It has not synced since Wednesday.
I wrote Fitbit help and the answer was to come here.
I updated both my phone and the app. Is there some way to force a sync? I had a way with my Fitbit one, but don't find a way anymore.
04-21-2018 22:36
04-21-2018 22:36
It has not synced to phone since Wednesday.
Tried the connect to charger. Got a number to show up. Tried that 3 times. Not working.
Updated phone and app. Removed app and reinstalled and signed back in.
Turned off phone and back on.
Removed fitbit from bluetooth and re-added.
Still nothing is showing up on app.
04-21-2018 22:51
04-21-2018 22:51
I tried going to the rectangular icon on the app and there is no update. On the sync now, there is a red circle with explanation mark when I tried.
Still no data showing since Wednesday.
04-22-2018 05:10
04-22-2018 05:10
The one important information that I don't see in your posts are the type of phone that you have.
Have you restarted the Charge 2 yet?
You say that you removed the Charge 2 from the Bluetooth and re-added it. I don't understand what you mean by re-add since this is not something the user can do but must let the app connect the tracker to the Bluetooth .
Please remove the Charge 2 from the phones Bluetooth, restart the tracker and try a sync again.
Do not remove the Charge 2 from your Fitbit account.
Have you checked the help site for sync problems?
There are pointers that I might be able to add if I knew the type of phone
04-23-2018 15:47
04-23-2018 15:47
Best Answer04-23-2018 22:24
04-23-2018 22:24
I got it working by turning off the phone completely and left it off for about 5 minutes.
Then went to the app where it says it synced last Wednesday and touched that and instead of the red circle and an explanation point, there was a circling c. I kept checking it as it kept going around and it took almost 30 minutes of waiting before it stopped and then it synced and has been fine.
04-24-2018 05:59
04-24-2018 05:59
I am having the same trouble and I have done all you have said and still nothing
04-24-2018 06:09
04-24-2018 06:09
It took more than just turning off the phone. Before that I connected the charge cable and after the battery picture came up, pressed on the little button for a few seconds until a different image came up and some numbers. I also updated the app and my phone. Also removed the app and reinstalled it. And after each thing tried to force a sync. Some combination of all that must have done something. It took a while. But it's been good at last.
04-24-2018 15:17
04-24-2018 15:17
I followed the steps and it worked. Then I did not sync again for a week and today I’m having the very same issues:
currently the Fitbit charge 2 doesn’t even show up as a device available to connect via Bluetooth.
I have removed this device from the app, and can’t reconnect it because it can’t connect to blue tooth. Suggestions welcome!
04-24-2018 15:55
04-24-2018 15:55
07-24-2018 23:24
07-24-2018 23:24
Hi, I'm having the same issue. I'm down to 10% battery. I tried the restart, but it won't work.
Best Answer07-25-2018 03:22 - edited 07-29-2018 09:26
@HazelGrant both the S7 and the S7 Edge are on the compatable list. My neighbor did not have problems with their S7. We should be able to help.
@Carmela.G the first step is to charge the battery up, then maybe try a restart.
07-25-2018 16:58
07-25-2018 16:58
08-10-2018 07:16
08-10-2018 07:16
Hi, Pleased to say this has worked for me, but I wonder why this simple solution is not listed in the syncing troubleshooting items. It would have saved me a lot of time and stress.
08-10-2018 07:23
08-10-2018 07:23
Best Answer08-12-2018 15:38
08-12-2018 15:38
Hi Rich,
I bought a new charger and my Fitbit works again. I've had the Fitbit for only two months, disappointing that I had to replace the charger so soon.
Thanks,
Carmela
Best Answer09-24-2018 11:49
09-24-2018 11:49
So far, this seems to be working.
Best Answer09-25-2018 13:01 - edited 09-25-2018 13:02
