02-16-2018
09:50
18:54
02-16-2018
09:50
18:54
Hi, for the past 3 days my charge 2 has not been syncing to my android device. I have tried force stopping the app, turning Bluetooth on and off, I have turned my phone on and off and uninstalled the app and it still is not working. I do not know what else to do please can someone help?
Thanks, Jane
@betterandbadder wrote:Do you lose all your data if you delete?
@betterandbadder I'm not sure what you mean by delete, any data that has synced to your account can not be deleted.
hey @Rich_Laue!
I just checked my phone's bluetooth and the old Charge 2 WAS still on the list of paired devices - "not connected" but still listed. I told the phone to "forget this device" and I will try again to pair it with my Mom's iPhone 7.
Thank you for the tip!
I hope you are doin' great @KateyBrie! I hope that the tips that @Rich_Laue has shared, helped you out.
If you have further questions or comments, let me know!
Hi! I have had the same problem with my Charge 2, but my Android Galaxy J3 Eclipse does even recognize the Charge 2 as a saved device, and therefore I cannot 'forget' it or 'unpair' it. Does anyone have any other tips that have worked to restore syncing?
@Rich_Laue wrote:I'm not sure which phone is being used, I find with android, removing the tracker from the Bluetooth menu, not the Fitbit app,, or clearing the Fitbit apps cache helpful.
Hi!
I’ve had my Charge 2 for about 8 months now and love it. I’ve had problems with the sleep stages once before but got it figured out.
The sleep stages were working perfectly until about 2 weeks ago. I haven’t changed how I am wearing it - location or how tight it is - and I have tried the plugging the Fitbit into the cable and restarting it. That hasn’t helped either.
I also deleted the charge 2 from the app and then reinstalled it. Still hasn’t given me sleep stages.
Help please?
Hey guys, welcome aboard!
@Molly_Ann, oh! Well, since the Samsung Galaxy J3 Eclipse isn't on the compatible devices list, so I'm afraid that you'll experience connectivity issue. If you haven't, please review the troubleshooting in the help article: Why won't Fitbit device sync? And let me know how it goes!
@Bexmeow14, are you getting some sort of error message on the Fitbit app? When you try to review the sleep stages? If so, let me know what it says.
I'll be around!
You are not alone. I am looking for a record board that posts how many times a user has to reboot the charge 2 every month. Does anyone know of such a place? I am sure the complaints would be astronomical.
I got my wife a Charge 2 and had to return it because she said if it doesn't work she didn't want it. My daughter's fitbit has to be rebooted several times a month as well.
I think this is a big problem that is being hidden by fitbit.
I just spent 40 minutes trying to pair my Charge 2 again. After only two weeks.
Harold Buchanan
I have to restart my phone every single day and sometimes multiple times a day so that I can get notifications.
Hello everyone. Thank you for trying the suggested solutions. For the ones who haven't you can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on. If the issue persist please let our Support team know about this.
Keep me posted!
02-13-2019
20:01
06:38
MarcoGFitbit
02-13-2019
20:01
06:38
MarcoGFitbit
Why does this has to be done every two weeks?
Moderator Edit: Format.
@Haroldbuchanan wrote:What are you talking about? I have to remove the app remove it from bluetooth turn off phone and start from scratch every three wekks. IT SUCKS
@Haroldbuchanan I have not had to ever start from scratch to get the Fitbit to sync. If you would like help in knowing what has worked for your fellow Fitbit users, please include your phones type.
Currently as Fitbit users, some seem to experience major sync issues with the latest Android app.
I rolled back to 2.85 and it had been syncing without issue.
I would use Google to search for your answer @jmdearras. without knowing which OS your phone runs i can not say.
Hello,
Same problem started to show up yesterday. Charge 2 shows the steps correctly, but could not sync to fitbit app in my iPhone.
Tried turn off/on bluetooth, power off/on iPhone, remove fitbit app/reinstall, none help.
What else can I do to fix it?
Thanks
Best Answer@xwu your Charge 2 does not need to show up as connected to be able to sync.
One of the first steps to try with a sync issue is to remove the Charge 2 from the Bluetooth list.
Other things to try is restart phone, better yet shut phone down, restart tracker. Check for phone and Fitbit app update.
The steps or referenced in the post above.
Best AnswerMy Charge 2 will not stay on. I followed all the steps to restart it and it still wont stay on. It gets a full battery and I take it off the charger. It stays on for maybe 10 minutes and then it's off again. What else can I do?
