01-18-2019
12:46
13:05
01-18-2019
12:46
13:05
Fitbit Update 1/18/2019: If you see the Fitbit logo and error 001 on your tracker, please see this link and restart your tracker. This should resolve the issue. If you are still stuck, please let us know.
Actively managing your weight? Find accountability buddies on the Manage Weight board
My charge 3 will only display 001 and I tried to restart but still only shows 001
Hey there @joelseph25, @jacock, @NatChapman, @Stayler, @RachelBeach, @stspang, @Joecalise! As mentioned above, we are aware that some have reported changing the clock face cures a blank screen. Did you try changing the clock face? If not yet, change the clock face in the Fitbit app. If this fixes the issue, you can change the clock face back to the original clock face.
Hello @paladinSF! I'm glad to hear that our Customer Support helped you out. Thanks for sharing the outcome!
Hi @tryagain50 and @BigDave1966! Great to hear you're back on track my friend! ![]()
Ping me out if you guys need further assistance!
Hi Marrefitbit,
i did not. I instead turned if all day sync, just turned it back on yesterday to test. So far the 001 issue has not re-occurred. I decided to try this approach when I saw several other users still experience the problem after changing the clock face and it appeared to be a opportunity for corrupt data to possibly impact the application running in the unit. I will let you know if the problem resurfaces.
Looking forward to a future update to correct the other quirky issues with the model 3.
Otherwise I like the unit. Just isn’t as stable/reliable as you’re other offerings as yet.
Best AnswerReceived Charge 3 for Christmas. First unit started connect disconnect from bluetooth. Noted incorrect time of day listed. Fitbit replaced the unit and overhauled what ever to connect with my account and update the new unit.
The replacement unit within less than a week has a screen error as described. discharged the battery and not log in info assuming it did not collect info. Within an hour of contact with Fitbit and resetting the unit the error message has appeared twice. Fitbit is now shipping a second replacement. Hopefully the third time is a charm. If not I cannot recommend Fitbit Charge 3. Has Fitbit gone cheap. The band connectors are now plastic? First clue?
Best Answer@KateFitbit I have had the same issue as everyone, sudden flutters and then my Charge 3 just gave in. Error code 001 was then displayed. I tread what you said to restart, got the smiley face and still nothing 😞 Please help or advise as to how to go forward?
Regards
Hi @stspang
Your post was moved into this existing thread on the problem. Please check out the first post from Moderator @KateFitbit for updates on the situation.
Best AnswerI took my new Charge 3 yesterday out of the box and only after a few hours this 001 error occurred. I could restart the tracker, but after this the syncing hasn't been working anymore. Also the error came back again during the night. I have tried to uninstal and instal the app again, same with bluetooth and any other steps I have found online with no results.
Any help for this situation? I really wouldn't want to return the tracker 😞
Best Answer@KateFitbit, I was initially able to solve my issue by uninstalling and reinstalling the Fitbit app and disabling the 'Always Connected' option from with in the app, I had no 001 error and no syncing issues for about a week which was awesome. Unfortunately since your app update (Android app) a couple of days ago, Monday/Tuesday from memory, I've been getting 001 errors several times a day and have also had difficulty syncing.
Cheers
Joel
Hi guys @kitkatkaycee and @Stayler! I'm glad to hear that the inconvenience with your Charge 3 has been solved. Thanks for sharing the extra recommendations!
Hi there @Ping10000, @SunsetRunner, @Avenant12, @stspang, @Katrisohvi, @Thodgens, and @joelseph25! Thanks for trying the tips and recommendations provided here. If you've also tried what @Odyssey13 has recommended above, I'd suggest to restart Charge 3 using the 15-second method:
Give this a shot and let me know how it goes!
Hi @Ping10000! I'm glad to hear that you just received your Charge 3 replacement yesterday. I'd like to give thanks for the feedback you've provided towards our product. Rest assured that our engineers and product development team use this information to further improve our products and services which lead us to release new Fitbit trackers.
Please know that we provide feedback to our team based on community posts and we are always working on improving our devices and overall environment based on that feedback.
If there any questions present, please let me know.
