10-30-2018 07:09 - last edited on 11-17-2020 15:03 by MatthewFitbit
My Charge 3 has stopped vibrating for all notifications. I've checked all settings on my Fitbit and phone and all is set correctly but still no vibration!!!
unhappy 😢
10-30-2018 07:14
10-30-2018 07:14
Have you tried restarting your device?
To restart you will need to place your Charge 3 into its charger and confirm that its charging. Then press and hold the button on your tracker for 8 seconds. When you see a smile icon and the tracker vibrates, the tracker restarted.
Give that a go and see if the vibration is restored.
10-30-2018 07:14
10-30-2018 07:14
10-30-2018 07:22 - last edited on 09-14-2021 06:17 by JuanJoFitbit
Smiley face yes 👍🏼 Vibration No 👎🏽
Restarted my fitbit again. Happy smiley face... didnt vibrate but now i have vibrating notifications
thankyou for your help
Moderator edit: merged reply
10-30-2018 10:30
10-30-2018 10:30
Excellent! I'm glad things are working as they should for you now
11-01-2018 07:17
11-01-2018 07:17
12-02-2018 02:11
12-02-2018 02:11
I did this but still no vibration or lighting up of screen when get messages
12-09-2018 23:01
12-09-2018 23:01
Hi, I looked at your solution and tried r out. The vibrator is definitely not working. I purchased this item for the day it was released and have been happy up until now. What can you do to help? I purchased the item on Amazon.
12-09-2018 23:51
12-09-2018 23:51
Hey 😊
Try holding the button on the side until the Screen Wake & Notifications screen shows Make sure both these are on. Good luck 🤞🤞🤞
12-10-2018 00:08
12-10-2018 00:08
01-31-2019 04:29
01-31-2019 04:29
I have a Fitbit Charge 3. It does not vibetate when my alarm goes off or messages or phone calls. I have reset and reset also called Fitbit and they have not gotten back to me. Ugh.
01-31-2019 15:19
01-31-2019 15:19
Hello. I've read the solution and reset my watch till the smiley face appeared and it's still not vibrating. All my settings are right 😞 what can I do?
02-04-2019 19:32
02-04-2019 19:32
I did that and all the other things I’ve read so far to do, and mine still will not vibrate. Ugh!
Do you know of Nything else to try?
lisa
02-04-2019 22:39
02-04-2019 22:39
02-04-2019 23:18
02-04-2019 23:18
02-05-2019 05:23
02-05-2019 05:23
02-05-2019 07:40
02-05-2019 07:40
I bought it as soon as it was released. And about a week after it stopped. I tried everything in the end I contacted Fitbit and returned it for a new one. And now... no trouble x
02-10-2019 16:52
02-10-2019 16:52
Scrolling through the menu on the watch itself, I stumbled on Settings -> Vibrations. Set it to Strong and that seems to fix the problem
02-10-2019 19:41
02-10-2019 19:41
04-28-2019 12:14
04-28-2019 12:14
Hi
This did not do it, still no vibrating on my charge 3 🙁
How can you help?
05-01-2019 11:57
05-01-2019 11:57
@Sylliev Welcome to our Fitbit Community! Since your Charge 3 is still unable to vibrate after following the restart process, I'll send your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
Let me know if you have any doubts!
