10-30-2018
07:09
15:03
10-30-2018
07:09
15:03
My Charge 3 has stopped vibrating for all notifications. I've checked all settings on my Fitbit and phone and all is set correctly but still no vibration!!!
unhappy 😢
Best AnswerThanks for the reply and siggestion...it doesn't work, I also tried the 8 second and 15 second reboot and vibration is always on in the app... I'm beginning to think that the vibrations mechanism is broken as no vibrations when it turns on / off either 🤔
Best AnswerI tried restarting and still does not vibrate for notifications ( text, 10,000 steps, move at 10 to the hour) My charge 3 was recently updated, could that be part of the problem?
Best AnswerHi,
Thank for this 🙂 I appreciate it - I've tried setting all that you suggested to off and have repeatedly set the timer to 1 second and no joy. I also pressed and held the button and reset the sleep and DND to off and still no vibrations. Was it the timer you had to set off 6 times? I've tried that too 😒 and nothing.
Take care,
Claire
Best Answer😒 sorry you're having the same issues - let me know if you find a fix. I'll post here if I do 🙂
Best AnswerThanks, I've tried that and it hasn't worked
Best AnswerWhat temporarily worked for me was to do a countdown timer and tap the face of the watch with my finger very hard at the end of the timer. Eventually that stopped working and I replaced with an Apple Watch.
