10-22-2018
		12:38
		15:03
		10-22-2018
		12:38
		15:03
I think there's an actual issue with my fitbit but thought I'd post in here to see if anyone else was experiencing a similar issue.
I bought my charge 3 just under two weeks ago. Last Friday, I noticed my screen looked faded and had white lines running through it. I have tried to reset it three times as generally suggested with no such luck.
I haven't damaged it in any way and I've continued to wear it in the shower as I wasn't concerned due to it being waterproof. The day the faded screen/lines appeared was when the battery was very low - but that's the only thing I can think of and surely a low battery should'nt lead to this?
Anyone's help would be greatly appreciated before I have to take it back. I've tried to add a picture to this thread but can't for some reason.
Many Thanks
05-05-2019 16:22
05-05-2019 16:22
05-06-2019 09:58
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              05-06-2019 09:58
Hi @Bethchelsea and @Mh84, welcome to our Community Forums.
It's nice to hear from you @Julieramsey54. Thanks for helping our new friends, and I'm glad that you're getting a new device.
@Bethchelsea and @Mh84, I've checked with our Support Team and apparently they already took your case under their wings. Please keep an eye on your email inbox, you'll get some information about your case.
See you around.
 Best Answer05-06-2019 10:14
05-06-2019 10:14
Hello,
I am also having this problem unfortunately. After several months of it working fine the screen had gone very white (the attach image option on the form doesn't work on my phone for some reason but happy to send an image).
I've tried restarting/rebooting, clearing user data and changing the clock face but nothing has worked.
Any help would be appreciated.
Best wishes,
Aisha.
05-06-2019 11:45
                              05-06-2019 11:45
Hi @Superaish, it's nice to see a new member around!
Thanks for letting me know about your Charge 3 behavior, as well for the troubleshooting steps tried. I also appreciate your efforts in trying to attach a picture. Because your device is still not working, I've gone ahead and requested a case for you. Our Support Team will contact you back via email with more details.
Keep me posted. ![]()
 Best Answer05-06-2019 12:33
05-06-2019 12:33
I'm having the same issue too. Tried everything to reset. This must be an issue with the tracker. Anyone have success with resetting? I'm frustrated after years of being a Fitbit supporter.
05-06-2019 12:40
05-06-2019 12:40
Thank you @LizzyFitbit!
05-06-2019 14:58
                              05-06-2019 14:58
Hi @Becrebecky, welcome to our Community. It's nice to hear from you @Superaish and you're very welcome. ![]()
@Becrebecky I appreciate your efforts in restarting your device. I understand how you're feeling and rest assured that I'm here to help you. I've contacted our Support Team so they can create a case for you. They'll be contacting you via email with more details about your case.
Keep me posted.
 Best Answer05-06-2019 15:38
05-06-2019 15:38
I am having the same issue and am eager to learn of a fix. My Charge is 4 months old and I have never cared for the sync cable connection as it seems loose. The vertical white lines appear as I removed the cable from charging.
 Best Answer05-06-2019 17:31
                              05-06-2019 17:31
Hi @Dragoness19, it's nice to see a new member around.
Thanks for letting me know about your Charge 3 behavior. Since you mentioned that the sync cable connection seems loose, do you mean that your device isn't always syncing with your phone? If so, may I know the model of your phone?
In the meantime, to fix the display issues, please try restarting your device with the following steps:
1. Plug the charging cable into a USB port from a computer or a UL-certified adapter into the wall.
2. Clip the other end on your Charge 3 making sure the button aligns with the little opening.
3. Hold the button for 8 seconds and a smiley face icon should be displayed.
Let me know how it goes. ![]()
05-06-2019 18:01
05-06-2019 18:01
Thanks for the quick response @LizzyFitbit !!!!! The cable connection from the cable to my device seems loose. Have not had an issue with the phone. (iPhone 6 plus) Also, tried the instructions you provided- connection to cable, holding button until smiley face appears. It did not help. Any other suggestions I can try?
05-06-2019 20:05
05-06-2019 20:05
Mine started to do the same thing but then it was fine... just last week it had the lines again
 Best Answer05-06-2019 20:11
05-06-2019 20:11
But now not only is there lines... when I turn my wrist to look at the time it doesn't turn on but randomly at some point some time in the day the clock will just turn on. I'm not only A bus driver that needs a clock But also I work in a child care center and I need to know what time it is at all times. getting really frustrated thinking about getting a different brand waterproof
05-07-2019 00:18
05-07-2019 00:18
05-07-2019 11:12 - edited 05-07-2019 11:13
Hi @Dragoness19 and @Steph99, it's nice to see you around. @ALICE9470, welcome on board.
@Dragoness19, thanks for confirming about the connection with the charging cable, as well for trying the restart. I was informed by our Support Team that a case was opened for you, so please continue working with them as I'm sure they'll take care of you.
@ALICE9470, I see your point of view about having a working device, and appreciate you for sharing your experience with it. Just to confirm, have you tried restarting your Charge 3?
@Steph99, thanks for stopping by to help our friends. I'm glad that you had a wonderful experience with our Support Team and hope to keep seeing you around.
 Best Answer05-07-2019 11:16
05-07-2019 11:16
If yours is still under warranty they are shipping out new ones.... they should just come out and recall them all there is obviously an issue with the Charge 3... which makes me wonder how long my replacement will last when it arrives since I have only had mine since Dec 😞
05-07-2019 11:22
05-07-2019 11:22
@Mh84 I've only had mine since January this year.
The support team are great though and they are asking about my warranty.
05-07-2019 11:33
05-07-2019 11:33
Yes support is great but they should make an announcement and just recall them and fix them. I have a feeling that my new one will do the same if the issue hasn't been fixed before sending out new ones.
05-09-2019 07:14
05-09-2019 07:14
Yes, I have tried many methods to resolve the issue and I've read the entire thread. I don't know what else to do and I really just want to have a nice tracker. It picks up readings even when I'm not moving! It would be nice if something which I paid almost $200 for would work.
Maybe a new case could be open for this, in the meantime I am getting a different tracker and possibly having this as a reserve backup.
Fitbit has NEVER DISAPPOINTED ME BEFORE.
RECALL THEM PLEASE.
05-09-2019 07:18
05-09-2019 07:18
Agreed!!! A recall is needed. Now that the white lines showed up I have a hard time swiping and starting exercises. Its very annoying. Its like the lines have made the touch screen almost unusable as well
05-10-2019 10:04 - edited 05-10-2019 10:09
Hi @Mh84, @Superaish and @ALICE9470. It's nice to see you here.
I'm sorry for the delayed response. I appreciate you for taking the time to share with us your feedback and thoughts about your experience with our Fitbit products and Support Team. Fitbit is constantly working to improve our products and overall environment based on our Community posts, so be sure that your comments will not be taken for granted.
@ALICE9470, thanks for confirming that you've tried a restart and because your device is still not working, I've requested a case so our Support Team can give you a hand. You'll receive an email from them shortly.
I'll be around if you need anything else.
