10-13-2018 16:21 - last edited on 11-17-2020 15:06 by MatthewFitbit
Got this yesterday and the screen is already black and won’t turn on. Very very disappointed, looks like it’s a common issue. I’d rethink getting this, a shame it’s so common for the anticipation of this...
03-23-2019 07:26 - last edited on 03-23-2019 16:04 by SelmaFitbit
Welcome on board @wolf_s_fang7! Thanks for trying to restart your Charge 3. You can try following @drdl's suggestion to see if you can restart your device.
If the restart does not work, but your Charge 3 is still syncing or vibrating I'd recommend changing the clock face to a different to see if this brings back the display. Steps can be found at: How do I change the clock face on my Fitbit device?
Hello @sthomsonacrt! I'm happy to hear our Support Team was able to help. If you need further assistance, don't hesitate to reply back to your support case. They will be more than glad to assist.
Catch you later guys!
10-15-2018 12:09
10-15-2018 12:09
Welcome to the Fitbit Community @jake1888, hope you're doing great! Sorry to hear that your Charge 3 display went blank. This may be fixed by a restart:
Give this a shot and let me know the outcome!
10-15-2018 13:22
10-15-2018 13:22
Identical issue, purchased a day ago, charged, sync, it was working fine for a day and then screen went back and it's not responding to anything and does not sync. Last time i checked few hours ago, battery was at 88%. Fitbit, please fix the bug in Charge 3. I probably should have waited before buying this new watch so quickly... Please check customers comments reporting sync and black screen issue on the web..
10-17-2018 12:19
10-17-2018 12:19
Mine is doing the same thing! I fully charged it two days ago and it still had a bunch of battery left. Then today the screen went blank and I can't get it back on. The sensor is still green and lighting up but nothing else. Very disappointed since my Charge 2 worked great but I already sold it. I'm going to go return it to the store...this is ridiculous since it seems to happen with everyone.
10-24-2018 05:33
10-24-2018 05:33
I had the same issue and tried your suggestion. Reset fine! Is this a software bug or hardware issue, do you know? Seems like it happened to quite a few folks. Thanks for the solution.
11-19-2018 14:48
11-21-2018 16:57
11-21-2018 16:57
Worked for me! Thank you!
11-21-2018 18:01
11-21-2018 18:01
This has happened multiple times for me. I am not keen on dragging out my computer and cords when I simply want to know the time and my heart rate. Fix this nonsense.
11-29-2018 13:00
11-29-2018 13:00
Tried to do the reset and it still does not work. So what next
11-30-2018 12:36
11-30-2018 12:36
Mine did the same but I was able to fix it. Put the fit bit in the charger (has to be in the charger) and hold the button on the side for about 8 seconds. A smiley face should come up and start working correctly. At least it did for me.
11-30-2018 16:16
11-30-2018 16:16
Mine was blank, wouldn't restart, nothing on the screen even on the charger. I probably restarted it 8 times, and it finally worked. Frustrating, but I haven't given up yet - not really much different from my laptop today, sadly...
12-01-2018 08:36
12-01-2018 08:36
Hi this process worked, my Charge HR3 display is working now.
12-02-2018 16:26
12-02-2018 16:26
This is the 2nd time my Fitbit charge 3 has just gone to a black screen? It is synced and vibrating when a message comes through the screen stays black.
12-05-2018 10:16
12-05-2018 10:16
This just happened to me and your instructions worked perfectly.
Thank you!
12-07-2018 10:13
12-07-2018 10:13
Same thing happened to me yesterday. I've owned it for about a month. The instructions on resetting worked. But I hope this doesn't happen again, it wouldn't bode well.
12-07-2018 12:15
12-07-2018 12:15
Glad you guys got your to work!! Mine still has the black screen. Fitbit customer service has been great and sent a replacement so hopefully I'll have better luck!
12-08-2018 18:58
12-08-2018 18:58
Hi - my screen did not come back on while on the charger. It was charged about 80% and screen just went blank - it vibrates when you tap that sides - but blank / black screen. 😞 it’s only a few weeks old. Any other solutions?
12-10-2018 14:46
12-10-2018 14:46
Thank you this helped the problem.
12-13-2018 11:12
12-13-2018 11:12
That’s just worked for me is it a big?
12-17-2018 08:15
12-17-2018 08:15
I was at work and i love having my charge 3 because i can put my break timer on it. Most of the time i dont carry my phone. My charge 3 screen went black, it was charged. First time this happens. I went home and looked up online help. Plug it to charge and hold the button 8 seconds it should restart it worked. I hope this doesnt happen again.
