10-06-2017
15:03
17:15
10-06-2017
15:03
17:15
My fitbit flex 2 is not counting my steps.
12-28-2017 09:32
12-28-2017 09:32
Best Answer12-28-2017 09:57
12-28-2017 09:57
Having the same issue. Received the Flex2 as a gift last Thursday and it's been working fine until now.
Wore the tracker to sleep last night; recorded sleep fine, as well as steps yesterday. Plugged the tracker in to charge since it was at about half charge and went and took a shower/got dressed. Put tracker back in wristband and went to WalMart. Wandered back and forth a bit (losing and trying to find someone in the store ups the steps count even if not intentionally, lol) as well as making at least a full circuit to get the items on my list. Came home and synced device and am now at only 748 steps. Find it incredibly hard to believe that I walked only 145 steps from parking lot into store, around store, back to car, into house, etc especially going off previous shopping trips and logging about 2k steps in similar scenarios earlier this week.
Have tried resetting the tracker 3+ times, have turned bluetooth off and back on, have restarted my phone. Steps still missing.
12-28-2017 22:02
12-28-2017 22:02
Restarting wont bring back the lost steps. They are gone unfortunately. Restarting will hopefully see that it doesnt happen again.
Helen | Western Australia
Best Answer12-29-2017 09:34
12-29-2017 09:34
Hey @Karship, @1862 and @heaven13. Welcome to the Forums @heaven13.
Thanks for bringing this to our attention. Our team is aware of this situation and it is being worked on. At this moment we do not have any further details or updates on the situation but we'll be sure to let everyone know whenever we do receive any news.
Thanks for your understanding. If you have any further questions please let me know.
Best Answer12-29-2017 10:26
12-29-2017 10:26
12-29-2017 12:18
12-29-2017 12:18
Best Answer12-30-2017 06:50
12-30-2017 06:50
Purchased my fitbit in Aug. and so far it has quit three times out of the blue....I get up one morning and it doesn't register with my iPad.Tried reboot and also let it rest for a couple of weeks or more with no results..The first time it shut down it just started back up after it rested...let the battery run out and waited for a week or so before recharging.Worked for a couple months and didn't work again.The lights still worked but no communication with iPad
Best Answer12-30-2017 08:31
12-30-2017 08:31
I was delighted to receive a Fitbit for Christmas. It worked for four days and then my phone app stopped showing any steps. The Fitbit needed to be recharged. After recharging I still could not get the app to show any steps even though the lights and app indicate that the device is charged and connected😩 i just deletedthe device from the app and reinstalled to see if that would help. I am disappointed to have this kind of problem so soon. How can I rely on any data it shows? It could be malfunctioning and I wouldn’t know, so what is the point of having it?
Best Answer12-30-2017 08:35 - edited 12-30-2017 08:44
How do I restart the tracker? Is that what double-tapping it does?NEVERMIND! I kept reading more posts and found the link from Nelly that showed me how to restart it. It’s not a simple procedure.
Best Answer12-30-2017 10:42
12-30-2017 10:42
Best Answer12-30-2017 11:00
12-30-2017 11:00
Best Answer01-01-2018 06:24
01-01-2018 06:24
Best Answer01-01-2018 14:23
01-01-2018 14:23
Best Answer01-02-2018 09:04
01-02-2018 09:04
Best Answer07-28-2018 18:01
07-28-2018 18:01
How can I get my Fitbit to record my steps again
Best Answer07-31-2018 12:46
07-31-2018 12:46
Welcome to the Forums @Lakewood32!
Have you tried going through the steps that have been shared in this thread? If so, please let us what steps you tried.
Additionally, could you let us know exactly what is going on with your Fitbit? How is it not counting steps? Do you see anything on its screen?
Look forward to your reply.
Best Answer07-31-2018 15:48
07-31-2018 15:48
my fitbit sync with my app or my computer. I know the Bluetooth is working on both. I felt my fit shake, when I hit my steps for the day, and all the lights light up but will not sync with either my app or computer.
still showing 0 on the app or computer
Best Answer08-01-2018 04:10
08-01-2018 04:10
08-04-2018 11:02
08-04-2018 11:02
Hey @ktrfalls, it is great to see you around more often! If the data tracked by your Flex 2 isn't transferring to your app or your computer, please restart your Flex 2 by following the instructions in this post. Then try to manually sync it and let me know if it works.
@Mommabare, how are you today? I'd like to know something. When you say that your Flex 2 isn't working after a few months without usage, what exactly do you mean? Could you please give me some details? If there is something that we can do to fix it, I'd like you to try that out. 😉
Keep me posted guys!
08-04-2018 13:16
08-04-2018 13:16
I was having a similar problem and did as suggested in other posts and this one but with no success. I had already deleted the app and restarted my iPhone with no success so I tried as was suggested in another post, I deleted the app, restarted the iPhone, and restarted the fitbit flex2 three times, and reinstallled the app, logged in and still didn't show any activity or steps correctly . So I called customer support. I was told to restart the fitbit again and open my app which I did and low and behold it showed the activity and updated the steps which it hadn't been doing correctly.. Problem solved, I guess it needed one more restart after doing as was suggested... Hope this helps somebody..
