12-30-2019 06:01
12-30-2019 06:01
Hi! I have ben using my fitbit Inspire HR for maybe a year now. This week i noticed that the battery would die almost by the end of each day. Normally I charge it every few days and it seems to be running perfectly fine. I did try to find previous posts that offer multiple suggestions such as turning off certain notifications/settings/etc. I have done that, but still, not much luck. I charged my battery this morning to above 50% (I was running late for work). Now I am at work and the battery is below 30%, and I don't have my charger with me at work.
I noticed there was an update on 12/24 (today is 12/30). Have any bugs been reported since the update? Are there any other suggestions on how to fix this issue?
Thanks and happy holidays!
Jess
09-05-2020 07:43 - last edited on 06-29-2021 05:14 by JuanJoFitbit
the same thing happens to me. one night is died and i charged. the next day i woke up to it being at 100%, then by that night (around 7) it was dead :((((
the same thing happens to me. one night it died and i charged it. the next day i woke up to it being at 100%, then by that night (around 7) it was dead 😞
i have this same problem
Moderator edit: merged replies
09-05-2020 09:29
09-05-2020 09:29
Hello, my inspire HR does not hold a charge for more than an hour. It started after a recent software upgrade Fitbit sent me. How can I fix it?
10-01-2020 17:00
10-01-2020 17:00
Hi, this is my second inspire HR, my first one died and I was shipped a replacement which has worked quite well until recently. Now I charge it and in less than an out it is down to 75%. It only holds its charge for a few hours then dies. This is the second inspire hr that has given me trouble. Any help would be appreciated. Thanks, Lawrence
10-07-2020 07:26
10-07-2020 07:26
I too am having the same problem with my inspire HR. It froze last weekend then it finally updated the firmware and now it drains in less than 24 hrs. I have tried everything that has been recommended and it's still having the same issue. It's just over a year old. I shouldn't be having this issue. I will not buy a fitbit again if this issue persists.
10-07-2020 08:59
10-07-2020 08:59
10-07-2020 13:05
10-07-2020 13:05
I've noticed my battery has lasted less than a day, for the last two days. It used to last about 5+ days and I have not changed any settings. there was no sign that the battery was going to fail. Just straight out died. its about 10 months old can I get some help with this please.
11-08-2020 11:29
11-08-2020 11:29
Did you ever find a solution to this? Mine started doing this in the last month. All of a sudden, doesn't hold a charge. Has to be some update??
12-12-2020 18:15
12-12-2020 18:15
My daughters Fitbit Inspire has recently shown these same symptoms. We have followed all the procedures to restart the device and change clock face settings and the device still drains the battery in a matter of hours. Is there a firmware upgrade for this? Is there a way to fix this?
12-13-2020 00:29
12-13-2020 00:29
I've just recently started having this issue with my Inspire HR as well. It goes from 30% to 0 in a matter of a couple hours and has recently being resetting or something like that in the middle of recording workouts.
12-16-2020 11:15
12-16-2020 11:15
@nelsaar @nmtsander I hope you are doing fine.
Let me help you with this and thank you for troubleshooting this issue. You can follow these instructions to help improve the battery life.
Let me know how it goes.
12-16-2020 11:22
12-16-2020 11:22
Thank you for the response. We have done several of these and the Fitbit continues to drain from 100% to dead in 3 hours.
12-17-2020 10:00
12-17-2020 10:00
@nelsaar thank you for your reply.
Since the issue persists I have created a ticket so our Support team can further assist you via email.
12-17-2020 18:44
12-17-2020 18:44
I've had the exact same issue.. bought it for black Friday last year I believe? So there goes the warranty I guess.. I've tried a hard reset and cleaning the port. That killed 3% in seconds. I had charged it to 60 this morning at 830( was also in a rush) and it was at 15% at 5 today..I'm super dissapointed.. hopefully an update will come?
01-21-2021 16:58
01-21-2021 16:58
The same thing is happening with mine. I used to be able to wear it for a few days between charges. Now I'm charging it multiple times a day.
01-24-2021 10:44
01-24-2021 10:44
@IsabelMG It's nice to see new faces around!
Let me help you with this. Have you tried the suggestions in my previous post? This should help you with improving the battery life.
I look forward to your reply.
02-02-2021 14:03
02-02-2021 14:03
I’ve posted this elsewhere, but will leave here as well:
Turning off my GPS solved this for me, ended up not being Fitbit but my phone. My phone gps is perfect on roads, but when I’m in enclosed places (my house, garage, grocery store, work) it struggles.. so my Fitbit was constantly dying while I was home or at work because it was constantly searching for my phone gps. Once I turned off gps it stopped constantly trying to search for it through my phone and my battery has been back to lasting 4 days before needing charged. It still accurately gives steps and miles walked/ran so I’m just going to leave it off.
02-02-2021 14:54 - last edited on 06-29-2021 05:16 by JuanJoFitbit
I contacted a Fitbit rep by calling them. I was losing double digit numbers or more daily and they had me watch it for several days as this could be a flaw in the internal battery. If it’s under a year, it’s covered by the warranty for a replacement.
If it’s under a year old, it’s covered for a new replacement.
Moderator edit: merged reply
05-03-2021 00:25
05-03-2021 00:25
I’ve been experiencing the same thing with mine. I’ll charge it for hours and it goes down like 10% every hour. Also it’s not letting me access settings on it or swipe to pick a walk or run for my exercise. Can you help me?
05-03-2021 04:58
05-03-2021 04:58
05-28-2021 13:33
05-28-2021 13:33
My 3rd fitbit that lasted a little over a year. Time to buy Garmin
