08-13-2019 08:18
08-13-2019 08:18
Got my Fitbit in Jan - no problems. Last night was the last time it sinced with my Android. My phone now can't find it. Any advice?
08-23-2019 07:18
08-23-2019 07:18
Yep, mine too...I actually set up a new device, it can find my one and sends the code but then it cant find my device after to sync...frustrating 😡
Best Answer08-23-2019 07:55
08-23-2019 07:55
Have had to restart mine again twice today, my Bluetooth isn't pairing with my fitbit apparently , tried to remove it and add it as a new device but as it's not there I can't remove it!
Best Answer08-23-2019 08:08
08-23-2019 08:08
Yep, still requires multiple restarts and wont stay connected
Best Answer08-23-2019 11:02
08-23-2019 11:02
I didn’t remove mine, just added it as a new device. I know it sounds weird but today is the second day and it’s still working. 🤞🏼
Best Answer08-23-2019 11:16
08-23-2019 11:16
Best Answer08-23-2019 11:38
08-23-2019 11:38
Having the same issue. I talked to tech support they blamed it on my phone. Now my One will sync with my Amazon Tablet. But Fitbit has been trying to get rid of the best tracker they ever made..
08-23-2019 15:11
08-23-2019 15:11
AMEN!!!!!!!!!!!!!!!!!
Best Answer08-23-2019 15:38
08-23-2019 15:38
Mine still will not allow sync..once after a reset but that's it
Best Answer08-23-2019 15:46
08-23-2019 15:46
Same here. But it will sync with my Windows 10 PC and then my phone syncs with my PC.
Best Answer08-23-2019 16:13
08-23-2019 16:13
I downloaded the application to my laptop but it says bluetooth is off. And I can't seem to find an application on the computer to turn on the Bluetooth there's no on-off switch so I don't know if it's not Bluetooth capable
Best Answer08-23-2019 16:17
08-23-2019 16:17
But trying to troubleshoot this multiple times during the day is getting old they are so pushing me on getting a new tracker and I'd really prefer not Fitbit..
I've sent two emails to support and no response that is just horrible customer service.. it's capable of setting up a new tracker and sending me a code but yet it cannot locate my device..I need the data for work wellness pts
Best Answer08-23-2019 16:39
08-23-2019 16:39
To sync to the computer, the dongle that came with my Fitbit One must be plugged into a USB port on my computer.
Best Answer08-23-2019 20:11
08-23-2019 20:11
If your computer is Windows 10, Bluetooth is in the lower right with other settings
Best Answer08-23-2019 20:12
08-23-2019 20:12
If you have Windows 10, it will sync via Bluetooth with the Fit bit app
Best Answer08-23-2019 20:14
08-23-2019 20:14
I need the wellness points also so I am syncing via computer. But my app works, sometime, without reset. Not sure of when OR how
Best Answer08-24-2019 03:02
08-24-2019 03:02
Mine also only syncing when I do a reset, I can't even add it as a new device because my Bluetooth can't find it.
I went into my Bluetooth settings to check whether my One is still there - it is, but when I tapped the device to force pairing, it gave the message "Pairing rejected by One". This is definitely a FItbit problem and not anything else - but hey, their sale ends tomorrow so maybe everything will be fixed then until the next sale!
08-24-2019 04:59
08-24-2019 04:59
So do we have an answer yet as to hoe to repair our pairing with our phones?
I did not see one in scanning the threads to this.
Best Answer08-24-2019 05:38
08-24-2019 05:38
Some people are having success, I am not resets are required daily for me..I also get the same message that pairing was rejected by the one
08-24-2019 06:20
08-24-2019 06:20
I think some of the people who report success after restarting or reinstalling haven't tried to sync more than once and discovered that the second time it doesn't work.
Best Answer08-24-2019 06:24
08-24-2019 06:24
I deleted my device and tried to reinstall it. At first, Bluetooth couldn't find it and I thought, well that's that. I tried again and maybe a third time and it found my One and paired. Unfortunately, it didn't fix the syncing problem. I still have to restart every time I want to sync to my phone. It does sync to my Windows 10 app on my PC, and my phone then will sync to my PC.
