10-14-2017 13:09 - edited 03-21-2018 10:28
I've been notified that there are reports of One battery draining quickly on iOS version 2.41.1 and our team is currently investigating. If you are experiencing this, we recommend disabling all-day-sync for now. I'll update this post once I hear more. Thanks as always for your patience and understanding.
Actively managing your weight? Find accountability buddies on the Manage Weight board
11-07-2017 17:18
11-07-2017 17:18
This solution worked immediately for me in solving my charging and dying problem. This is the response I received from Support:
Version:1.0 StartHTML:000000194 EndHTML:000359270 StartFragment:000356893 EndFragment:000359160 StartSelection:000356893 EndSelection:000359160 SourceURL:https://mail.yahoo.com/?.src=ym(429 unread) - llbertone@yahoo.com - Yahoo Mail
11-07-2017 20:01
11-07-2017 20:01
I have no idea what you are saying....
Best Answer11-07-2017 21:32
11-07-2017 21:32
11-08-2017 13:20
11-08-2017 13:20
My Fitbit one used to hold a charge for about a week. Now I’m lucky if I get a complete day out of it. Has anything been figured out yet?
11-08-2017 17:19
11-08-2017 17:19
I notice this to only last tops 3 days
Best Answer11-08-2017 19:11
11-08-2017 19:11
11-13-2017 14:57
11-13-2017 14:57
My Fitbit One was charged 4 days ago. Yesterday (3rd day) it showed that the battery was halfway charged (yellow). It died on me today without warning. I had no warning by email that it needed recharging. How come I am not gettng the email any more?
11-13-2017 16:53
11-13-2017 16:53
Best Answer11-18-2017 01:01
11-18-2017 01:01
This is happening to mine too. Had it 4 years without a problem now have to charge it every 36 hours or so. Thought it was dying and was worried as the one is not available anymore. Don’t like the zip and can’t wear wrist trackers at work so was thinking I’d have to fine a different tracker.
11-18-2017 08:02
11-18-2017 08:02
11-18-2017 10:18
11-18-2017 10:18
Best Answer11-19-2017 08:42
11-19-2017 08:42
I forgot t tell you that I also pressed the bottom button on fit bit one several times this took the up date off my fit bit one has been running for a week with very little battery discharge. hope this helps you more.
Best Answer11-20-2017 02:08
11-20-2017 02:08
Best Answer11-20-2017 06:44
11-20-2017 06:44
Ummm what ‘bottom’ button?
Best Answer11-20-2017 08:42
11-20-2017 08:42
Best Answer11-20-2017 11:36
11-20-2017 11:36
My Fitbit One battery is draining very quickly too. Will wait to hear update.
11-23-2017 04:36
11-23-2017 04:36
This continues to be an issue for me, as well as the app randomly not finding the One (if I try to sync, it sits and blinks with the plus sign) even though it is inches away. None of this used to be an issue between the Fitbit and either of my iOS devices. They've really monkeyed something up.
11-23-2017 09:20
11-23-2017 09:20
11-23-2017 10:24
11-23-2017 10:24
Interesting work-around, but for me I had to kill the app on both iOS devices AND reboot the One itself to get any of the devices to find it again. I reboot by plugging the ONE in via the charging cable into the computer, and holding the button down for 15 seconds or so. Perhaps there is an easier way.
Agree on the whole bluetooth connectivity being the likely culprit in this. Rather like having an iPhone search continuously for a wifi connection it can't find.
11-25-2017 13:36
11-25-2017 13:36
