10-31-2018
05:05
15:03
10-31-2018
05:05
15:03
One of my big questions is how easy can you read your Charge 3 in direct sunlight. I don’t need a watch/tracker that I need to cup my hands over to read.
05-07-2020 19:16
05-07-2020 19:16
I just received the same 25% off coupon to purchase a new Fitbit since I can't read anything on the display when outdoors. I've decided to buy a Garmin instead. Some of their older models are about the same price and rated highly for visibility outdoors which is the main feature I need when hiking. It's so frustrating to have no idea how far I've gone or for how long. Bye bye, Fitbit.
05-08-2020 06:48
05-08-2020 06:48
I have had this issue for months and tried fixing it by restarting the device, doing the hard restart and checking my brightness settings. I finally contacted support and they only thing they would do for me is give me a discount on a new product. Because I tried to correct it myself instead of contacting support right away I am being punished. The customer service from FitBit is horrendous and I will not buy another product from them again.
05-08-2020 07:07
05-08-2020 07:07
05-08-2020 07:17
05-08-2020 07:17
06-06-2020 14:38
06-06-2020 14:38
I also have the same issue. I can't see anything outside, not even the time. My husband has a somewhat newer Charge 3 and he can see his much more clearly. You really should handle this issue. As others have said it will be the last Fitbit I purchase otherwise.
06-07-2020 14:21
06-07-2020 14:21
Thanks, seeing it much more clearly is subjective, to me I would like to be able to see the clock face in the full sun, and shade clearly without question, all data.
I believe some Charge 3 can be seen in the sun, some, it’s a good product, just not outdoors.
06-09-2020 09:04
06-09-2020 09:04
06-10-2020 12:49
06-10-2020 12:49
That is completely false. It's impossible to see even the largest text including the digits of the clock even in overcast conditions, let alone in direct sunlight. And this is at the brightest setting. And yes I have perfectly good eyesight thank you for asking. It can only be used indoors.
06-10-2020 14:16 - edited 06-10-2020 14:20
No. My Charge 3 is useless outdoors. On an overcast day I can barely see the details on the screen, and in sunlight I might as well be looking at a Charge3 that's not even switched on. I've tried restarting it, resetting it, setting the screen brightness to auto or normal. I tried other watch faces too, and any where the text is even slightly greyed are absolutely hopeless. Combined with the constant "failed to sync" messages and the fact that it takes upon itself whether or not to start auto tracking an activity it's the worst fitness tracker I've ever wasted money on. I highly doubt I will buy another Fitbit product based on how this one has performed in the last 9 months. Disappointed doesn't even come close after chosing Fitbit over other more expensive options.
06-10-2020 14:40
06-10-2020 14:40
Just to be clear I wrote in response to AlejandraFitbits claim that the display can be read in direct sunlight. That is what is completely false. Steph3071, you are 100% right. It's useless outdoors in any kind of daytime lighting.
06-10-2020 15:54
06-10-2020 15:54
06-10-2020 16:01
06-10-2020 16:01
06-10-2020 16:04
06-10-2020 16:04
06-10-2020 19:25
06-10-2020 19:25
06-11-2020 05:17
06-11-2020 05:17
I cannot read my C3 in direct sunlight at all and only just outside in overcast conditions. It is also too bright at night! Have they got the light intensity logic wrong ?
Also mine has now stopped turning the screen on when I lift my arm up to read it.
As Fitbit don’t seem to be addressing the problem, what is the best alternative? I use mine to track cycling trips synching with Strava.
06-11-2020 05:50
06-11-2020 05:50
I would recommend looking at some of the alternatives from Garmin. They have Spring offers on at the moment if you go to the manufacturers website.
06-11-2020 15:25
06-11-2020 15:25
06-25-2020 19:51
06-25-2020 19:51
I having the same issue. Can’t see my C3 at all in sunlight. My husband has the same Fitbit device and is able to read his. I used to be able to see it, but as mine, too, changed during a recent update. I’m sorry read others have gone to other devices by other companies. I love my C3 otherwise but I, too, use mine as a watch. I’m disappointed and Fitbit hasn’t addressed this.
06-25-2020 21:44
06-25-2020 21:44
06-26-2020 04:13
06-26-2020 04:13
