09-26-2016
09:50
10:26
09-26-2016
09:50
10:26
I have a Charge 2, which I'm using with my Nexus 6 phone running the latest version of Android.
My issue is with the calendar notifications feature. Whenever a notification pops up on my Charge 2, it displays the current time, not the time of the event. So let's say on Google Calendar I have a lunch at noon, and it's set for a reminder 10 minutes before. The reminder notification pops up on my phone and on my Fitbit, but the Fitbit displays "Lunch: 11:50," rather than "Lunch: 12:00." Likewise if I have a reminder notification in Google Calendar for half an hour before, the notification says "Lunch: 11:30."
Anyone else have this issue, or know how to fix it?
09-29-2016 06:04
09-29-2016 06:04
It's nice to see you around the Community @dbull058, hope you're doing great! Your tracker will show calendar events and any information sent from your calendar app to your compatible mobile device. Note that if your calendar app does not send notifications to your mobile device, you won’t receive notifications on your tracker.
I also would recommend restarting your Charge 2 by following these instructions.
Hope this helps!
Best Answer04-01-2017 14:07
04-01-2017 14:07
Facing the same issue was this solved?
04-03-2017 04:52
04-03-2017 04:52
It's nice to see you around the Community @ayush! Hmmm... this is weird let me say. Have you double checked if your mobile device is included in our supported devices? If so, try the following:
Hope to hear good news! ![]()
Best Answer07-11-2017 22:41
07-11-2017 22:41
Hi ya,
With regards to the calender does it only work if you set calender reminders or can you just view your calender on charge 2 without having reminders set?
Best Answer07-13-2017 05:59
07-13-2017 05:59
Welcome to the forums @Napotter, hope you're doing great! You can use calendar notifications without having reminders to move set. ![]()
As you may know, Charge 2 vibrates when a notification is available and you have one minute to read it. If your screen is dimmed, turn your wrist towards you or press the button. Charge 2 doesn't save notifications so check your phone to see those you miss.
Notification tips:
Hope this helps! Have a great day! ![]()
Best Answer08-30-2017 07:05
08-30-2017 07:05
Same issue. Every time I get an alert for an upcoming event, it shows the current time instead of when the event starts. At work I have alerts 15 min before meetings. For private events I often set a reminder days before, but Carge 2 don't show when the event actually starts. It has never shown the correct time.
Can this be fixed somehow?
08-31-2017 06:32
08-31-2017 06:32
Hi Maria, one question on the + sign for many notifications. Is there any way to see them all in the Fitbit, or it just says so, and I have to go to the phone to check them? Thanks in advance. Gabriel
Best Answer08-08-2018 07:55
08-08-2018 07:55
It is now 2018 and I see the same issue. Clearly fitbit has a bug, but I doubt they plan to fix it at this point. Since the Fitbit rep on this thread has not been very clear as to what is going on, I am not holding out for a fix.
12-02-2018 23:36
12-02-2018 23:36
Chiming in again. It is now december 2018, and the bug is still present. I have changed phones (more than once) and the notification has never worked.
I love my Fitbit, but the support whenever things is not working (like problems with syncing) has never been good. Nothing but "try restarting" and not really answering or acknowledging the problem. Guess this is my last Fitbit.
01-29-2019 09:10
01-29-2019 09:10
I got my Fitbit Alta for Christmas (2018) and I came here looking for answers to this question because it drives me nuts. I get the notification an hour before each event, which is great, but instead of displaying the time of the event it displays the current time. It's easy enough to do the math since all my events are set to remind me an hour before but it's still frustrating that it doesn't work correctly. I'm sad to see it's been a bug for so long and nothing's been done to fix it.
Best Answer01-30-2019 23:06
01-30-2019 23:06
Best Answer01-31-2019 04:30
01-31-2019 04:30
Yeah, I am with you, this will be the last fitbit I own, I have had the same issues and it should not be that hard of a fix, at least the time issue.
Best Answer12-23-2019 03:32
12-23-2019 03:32
3 years later, this is still an issue...
Best Answer12-23-2019 03:37
12-23-2019 03:37
2019 and the issue is still here 😞
Best Answer12-23-2019 06:58
12-23-2019 06:58
and this is why I switched to a different fitness tracker, this should be an easy fix, but they don't care. I spoke with reps about it. Also when you do need to get it replaced they will try and send you a different size or color because they are out of stock.
