07-06-2017
05:00
11:40
AndreaFitbit
07-06-2017
05:00
11:40
AndreaFitbit
Losing sync on charge 2 every day. Have uninstalled software multiple times and still keep losing sync. Anyone have an answer.
07-08-2017 06:40 - edited 05-06-2025 07:06
For sure @Irishwings! I'm crossing my fingers.
I'll try mine too, I haven't had any issues yet, but I'll keep an eye on my GPS data from now on.
Thanks a million!
07-06-2017 05:28 - edited 07-06-2017 05:29
Hey there @Irishwings, it's great to have a new member here!
Thanks for already troubleshooting this by uninstalling and reinstalling your app, nice way to go!
For clarification, are you talking about the Bluetooth bond between your Charge 2 and mobile device?
If so, I'd recommend that you Bluetooth bond your Charge 2 to just your mobile device so you can use features like Connected GPS and receive notifications from your phone.
Additionally, I wouldn't recommend having your Charge 2 Bluetooth bonded to both to more than two phones at the same time. Having your tracker Bluetooth bonded to two devices at the same time may cause Bluetooth interference, which I think may be the root of the issue that you are experiencing.
By any chance are you using more than two devices with your Charge 2? If you are not, I recommend the following:
1. Restart your Charge 2.
2. Reboot your mobile device.
3. Re-pair your Charge 2 to your account using the replacement setup process mentioned here
4. Make sure that you have exercise mode set up on your Charge 2
Let me know if this helps! ![]()
Best Answer07-06-2017 08:27 - edited 07-06-2017 09:12
Hi there MarreFitbit. I am also having this same issue where the connected GPS is not remaining connected while cycling, which I do almost daily. It drops the connection to my phone when I enable the Bike mode. I still get my duration which is important to me but I'm not getting my pace which is also important. I'm also not receiving my smart notifications consistently so I feel it is a bluetooth issue.
Bluetooth on my iPhone works with my Alta HR consistently and with other bluetooth devices.
I have so far done all of the steps you mentioned:
- restarted and reset my iPhone (my iOS is also up to date)
- restarted my Charge 2 (more than once) using these instructions https://help.fitbit.com/articles/en_US/Help_article/1186
- unpaired/repaired Charge 2 to my phone using the app and bluetooth settings on my phone
- deleted the app after unpairing Charge 2 then reinstalling the app
Not really wanting to go restore the iOS, it's a pain to do but I can if I must.
Any other suggestions would be fantastic, thanks!
07-06-2017 12:46 - edited 05-06-2025 07:06
Hey sweetie @TSLady_Biker, thanks for stopping by and trying those steps already!
I was wondering if by any chance you have more devices linked to your account? If so, since you've unpaired/repaired your Charge 2 I'd recommend unpair all trackers/delete from Bluetooth settings in phone and please only keep the Charge 2 and give it another try to your connected GPS activity.
Looking forward to your response!
07-06-2017 13:00
07-06-2017 13:00
I will give that a shot. I won't have a chance to test out the connected GPS till I head home today so we will see!
Thanks for your response!
Best Answer07-07-2017 07:47
07-07-2017 07:47
Halo! Any updated on this sweetie @TSLady_Biker?
I was off when you replied me back, so I just saw your message.
Best Answer07-07-2017 13:31
07-07-2017 13:31
Best Answer07-08-2017 06:40 - edited 05-06-2025 07:06
Thanks a million!
07-08-2017 11:10
07-08-2017 11:10
Hey there Marre, it sadly didn't work. The connection dropped within a minute of starting my ride home 😞
Thanks again for all your help, any other ideas?
Best Answer09-06-2017 10:46
09-06-2017 10:46
Same thing here: I manually pair (why doesn't it do it itself?) and 3 times out of 4 it will drop before the end of my bike ride to the office. Distance is almost invariably wrong too.
Where are you with this? At which point do you give up and return the device/get it swapped (assuming it fixes the problem)?
Nice gadget - lots of little irritations...
Best Answer08-29-2018 02:24
08-29-2018 02:24
I’ve recently started having this problem too! Distance, pace and mapping is the reason I got a FitBit but if this is a common issue (and it seems to be!), I may not be buying anymore FitBit products when there are so many out there now. I’ve tried repairing my devices and my FitBit is only paired to my phone. Not sure what else to try? Does this seem to be Charge 2 specific?
Best Answer09-06-2018 10:23
09-06-2018 10:23
My Charge 2 has recently had issues of dropping Bluetooth connection to my phone as well. I've had to restart my Bluetooth connection and resync, it will work for a few days, then drop again. I didn't have this problem before, this is just in the last few weeks.
11-25-2018 05:28
11-25-2018 05:28
Thanks for the info on possible interference being connected to 2 devices. Turned Bluetooth off on old device and connection came back on new device
11:28
07:06
11-26-2018
11:28
07:06
@Cab4 Welcome! It's great to see you around! Happy to hear that your syncing issue was resolved and thank you for sharing your experience as this may help other members in the same situation.
I'll be around!
Best Answer01-12-2019 07:45
01-12-2019 07:45
I have the New 3 and this keeps happening to me all the lime and you do get fed up redoing over and over again! not very good right
04-02-2019 18:47
04-02-2019 18:47
My 3 cannot stay connected to my phone for the length of a workout. Fit bit has even sent me a new device. It's makes it makes why I bought this that totally but waste
Best Answer04-03-2019 09:39
04-03-2019 09:39
Best Answer04-03-2019 09:46
04-03-2019 09:46
I should not have to hike/walk with my phone in my hand to reconnect bluetooth every few minutes
Best Answer05-23-2020 17:26
05-23-2020 17:26
Very frustrating , I have re-paired the iPhone and charge 2 at least 6 times and not connection.,
Best Answer07-15-2020 13:36
07-15-2020 13:36
I have recently bought the new fitbit4 and it loses pairing to my mobile every day. I only have Fitbit Paired to my phone! Does pairing to your car interfere with pairing to the fitbit4?
