10-02-2017
12:22
09:26
10-02-2017
12:22
09:26
I brought a charge 2 yesterday, i have set it up but the only issue i am having is that the messages aren't being displayed, its only coming up with the name of the person that has sent me the message.under the notification display options I have checked the sender and message option but as i said I'm just getting the sender and not the message. Any thoughts on how i can fix this?
10-05-2017 07:12
10-05-2017 07:12
It's nice to see you around the forums @Greeneyes78!
Hmmm... is this the first time you have this issue with your notifications?
Let's try the following step-by-step:
PS: If you're on Android app, if the preview message is off then it won't preview through Fitbit either, no matter what you set it to through the app. So, check it by going to Settings --> Device --> Applications --> Messages --> Notifications --> Must be on, pop-up display switched on, and Preview Message on. ![]()
Give this a shot and let me know if that works!
Best Answer10-05-2017 11:55
10-05-2017 11:55
I tried all of the above and its still just displaying the name of the person and underneath it says 1 new message. If i use the "'messages"' default messaging app then i can see the message but I want to use the 'messenger'' default messaging app as this is my main way i get my messages.
Best Answer10-05-2017 13:23 - edited 10-05-2017 13:23
Thanks for trying the suggestions I provided @Greeneyes78!
Don't wanna bother you anymore my friend, but I'd like you to please check this thread and check what worked for @annie-nz. There are steps I already provided, but maybe I missed one of them.
However, I've created a case to get you in contact with our Support team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Best Answer09-14-2019 11:47
09-14-2019 11:47
my charge 2 had this problem from early July. I noticed today it is working again. Yay! I don't know if there has been an update.
