04-18-2019
23:45
16:45
04-18-2019
23:45
16:45
Hi I've had my charge 2 for around 2 years, i run around 5 days a week and my charge has always been fairly accurate with my distance and average run/ miles per minute time. But the last couple of days on routes I've done for weeks/months it's recording my distance and average mile times as a lot shorter and slower than they have ever been. A regular 3 mile run (9.53p/mile) is now a 2.75 mile run (11.39 p/mile). Also yesterday a measured 5.25 mile run I have done on many occasions is now showing as 4.46 miles?? Completely confused as to why suddenly it's changed. I ran last Saturday with my husband we did 6 miles he records his runs on Strava and our runs measured the same, Tuesday mines was fine but yesterday and today they're out. Can anyone help? Thanks
04-24-2019
12:53
10:23
04-24-2019
12:53
10:23
@MaryJo50 @Richmondrunner @TanyaGordon @Runningirl60 @Phillies2K8 Welcome! It's great to see you around!
I will gladly assist you with your activity detection. Your device detects activities based on the motion on your arm. The automatic detection is a feature called SmartTrack. For example when using the elliptical machine make sure you have the moving bars so your device detects the motion and record the activity itself. The same applies to step detection. There are situations in which your arm may be still but you could be moving or walking. This may happen when you are pushing a cart or holding bars while walking or doing treadmill. For added sensitivity you can try wearing your device on your dominant hand but select that hand as non dominant on the device’s settings to make it more sensitive to movement. Also make sure your hands are moving so the device can properly track your steps. Finally you can also enter your stride length to improve the distance calculation.
Let me know how it goes.
04-24-2019 18:15
04-24-2019 18:15
04-24-2019 23:36
04-24-2019 23:36
04-25-2019 00:56
04-25-2019 00:56
04-30-2019
11:45
10:24
04-30-2019
11:45
10:24
@TanyaGordon @Runningirl60 @MaryJo50 thank you for your updates and sorry for the late replies.
@TanyaGordon happy to hear that Support was able to help you with this.
@Runningirl60 @MaryJo50 you can follow the instructions in my previous post to measure and enter your stride length so this helps solve the issue.
05-19-2019 06:57
05-19-2019 06:57
05-19-2019 13:51
05-19-2019 13:51
When I am walking it is correct I count 100 and look at my Fitbit it is also 100 steps if I go into shop to buy my paper it jumps about 75 steps the same when I enter my home I keep my hand steady it jumps about 75 steps I have given up with it not truthful please help or it is for the bin does my head in it is now in my top drawer discharging the battery useless I paid £120 for it a total waste of money
05-19-2019 14:05
05-19-2019 14:05
05-20-2019 01:11
05-20-2019 01:11
