04-24-2018
14:58
18:54
04-24-2018
14:58
18:54
All of the sudden my Samsung Galaxy S8 is unable to pair with my Charge 2. It was working up until Thursday last week. Every fix I try has not helped...?
04-25-2018 05:25
04-25-2018 05:25
Welcome to the Fitbit Community @steph_iag, hope you're doing great today! Have you checked if your Charge 2 is still linked to your Fitbit account? If so, note that syncing difficulty is usually caused by a missing requirement. Verify each requirement posted below:
Depending your Android device, these tips might make syncing easier:
If your Fitbit device still won't sync, try these steps:
Give this a shot and let me know how it goes!
Best Answer07-20-2018 15:17
07-20-2018 15:17
I am having the same problem. My charge 2 was paired with my galaxy s8 with no issues. As of 1 week ago it will not pair. I've tried everything you suggested. I even uninstalled the app and reinstalled it.
07-26-2018 09:35
07-26-2018 09:35
@Amyn22084 Welcome to the Fitbit Community! I hope you're doing well! Sorry to hear that you can't sync your Charge 2 with your Samsung Galaxy S8 phone. Try going to your phone's bluetooth settings and remove all devices listed there. After this restart your phone and restart your Charge 2 by doing the following:
Plug the charging cable to your computer or UL certified wall adapter.
Align the contacts of the tracker with the charging cable and plug it in making sure it snaps securely.
Your tracker should start charging.
Press the button for 10 to 12 seconds.
You should see your tracker's firmware version and you can now unplug your tracker.
Open the Fitbit app and retry syncing them.
Let me know how it goes!
Best Answer08-14-2018 13:43
08-14-2018 13:43
I have tried all of these steps - and several others that I've found online. But on "sync now" on the app, it just keeps spinning and spinning.
So frustrating because up until two weeks ago, everything was working perfectly. I changed nothing, but they no longer seem to recognize each other. I don't get texts, nudges to move, nothing...
Best Answer08-24-2018 11:02
08-24-2018 11:02
Welcome to the Fitbit Community @wcunion, thanks for jumping in here and trying the steps provided! Please go to the Bluetooth settings on your phone and remove the tracker. In the list of Bluetooth devices you'll see the Charge 2 and next to it, this symbol "!". Hit the symbol and it will take you to the next step, once you're there select the option that says "Forget this device".
Once you've made sure about that, go back to the Fitbit app, go to the "Account" option in the upper right corner and select "Set up a Device". This should start the setup process for your device. ![]()
If you keep having syncing difficulties, please try the following:
Let me know if this works for you!
Best Answer09-01-2018 00:46
09-01-2018 00:46
Hi all, noticed many people having a sudden problem with syncing. My FitBit Charge 2 was not syncing with my phone or laptop for several days. I turned off/ on Bluetooth for both devices and reset the tracker several times with no luck. Finally, I went to my phone settings --> Apps --> FitBit --> force stop, and this seems to have resolved the issue. My alarms have synced and all the data is showing in the app via phone and laptop.
Hope this helps!
Amber
Best Answer09-01-2018 05:39
09-01-2018 05:39
I have exact same issue! Any solutions?
Best Answer09-10-2018 08:53
09-10-2018 08:53
Hey there @ambercucumber, thanks for jumping in here! I'm glad to hear that your tracker is syncing now after following the steps you mentioned. Thanks for sharing them! ![]()
Welcome on board @Parishillwalker! Are you still having syncing difficulties? If so, I was wondering if you've followed the suggestions I've shared in this post? Can you also try what @ambercucumber did?
Looking forward to your response!
Best Answer09-10-2018 10:43
09-10-2018 10:43
None of these solutions have worked for me. Has anyone else come up with something?
I've updated my permissions, but they never seem to stay in place. I've unlinked my Charge 2 from Bluetooth and the app only to restart then find the Charge 2 back in the app like nothing is happening. It's as if the app is just wiping everything I am trying to revert to a previous version.
Best Answer09-10-2018 11:16
09-10-2018 11:16
Best Answer09-10-2018 11:20
09-10-2018 11:20
Best Answer10-16-2018 05:23
10-16-2018 05:23
I am thinking of returning my charge 2. I've owned it for a month and had 5 different sync issue. I had a $50 misfit for 2 years and no issues.
I tried every step advised. No luck. I deleted app and my phone says it is bluetooth connected to soundfit but now the app cant connect to the charge
Best Answer01-13-2019 14:38
01-13-2019 14:38
Your not the only one.....everything was fine then all my messages were not syncing and after 2 replacements Fitbits best advice was to hold out till the next update whenever that is......its a $150 dollar watch.....
