05-30-2019 05:04 - last edited on 11-17-2020 10:58 by MatthewFitbit
The button on my Fitbit is stuck in and I can’t get it to pop back out. Consequently I have a blank screen. It still vibrates and counts my steps.
02-08-2021 14:05
02-08-2021 14:05
I had an issue with the screen within my warranty date and they sent a new one, now the button on the one they sent isn’t functioning and they sent me the same coupon for 30% off. Too many issues and inconsistencies, honestly I’m fed up and thinking of switching.
07-25-2021 02:12
07-25-2021 02:12
I have the same problem
07-26-2021 06:34
07-26-2021 06:34
Hello @BahmanJ. Nice to see you around.
I'd like to let you know that if the tips suggested in this thread haven't helped, I recommend contacting our Support Team for further assistance. Note that you can contact them through chat or over the phone, but phone wait times have been longer than normal, so I recommend initiating a chat. Click here to get connected.
Also, please make sure to provide a brief explanation of the inconvenience and mention the troubleshooting steps you've followed, this way they can assist you from there.
See you around.
05-01-2022 08:08
05-01-2022 08:08
I know this post is pretty old, but I am having this exact problem with my Charge. My button looks just like this. I am not able to sync and/or change clock face with app, as device battery is totally dead. I have 3 chargers & have plugged it into all of them (with various outlets, power cubes etc) hoping it was an electrical/charging type issue, but nothing helps. It simply seems dead. Should I just order a new one? I know it’s old by electronic standards. Is there an average reasonable life span expectancy for this type device & if so, I would love to know others’ thoughts on what that is.
Thank you so much!
06-20-2022 08:57
06-20-2022 08:57
I am having the same problem as Libbymary with the button on my Charge 3 stuck below the surface of the device. Can you share the fix that you sent her?
08-23-2022 01:39
08-23-2022 01:39
Hi, my fitbit versa 3 button is not working, ive tried to push it in numerous times but nothing. And everything you have suggested but still nothing. Ive only had the watch since feb this year. Can you please help? Thank you, K
11-28-2022 01:22
11-28-2022 01:22
After thoroughly cleaning the button(s), restart your Fitbit using the on-screen options and then see if the button works again.
Suspect the Fitbit's button is jammed?
Check your vibration settings.
Try restarting your Fitbit.
Check for water lock.
Drain the battery.
Reset your Fitbit.
Regards
Will
