05-30-2019
05:04
10:58
05-30-2019
05:04
10:58
The button on my Fitbit is stuck in and I can’t get it to pop back out. Consequently I have a blank screen. It still vibrates and counts my steps.
05-30-2019 05:09
05-30-2019 05:09
It might not be a problem with the button as there's an ongoing issue with some Charge 3 trackers getting a blank screen. Usually, one of the following fixes it:
Best Answer05-30-2019 06:11 - edited 05-30-2019 12:02
Welcome to the Community Forums @Libbymary! In regards to the button, it's a "flat button" which means it's not a physical button.
I'd recommend trying the restart recommended by @SteveH. If that does not work, please check that your Charge 3 is syncing (you can verify this in your Fitbit app) so you can change the clock face. Don't worry if the screen is blank, this process is done through the Fitbit app.
Give this a go and let us know the outcome, we'll be glad to further assist you. ![]()
05-30-2019 07:53
05-30-2019 07:53
Best Answer05-30-2019 10:39 - edited 05-30-2019 10:43
Hey there @Libbymary, thanks for coming back!
Can you please share showing how the button on your Charge 3 looks like? It should look like my image below:
If you had another Fitbit like Charge 2 the button is quite different on Charge 3.
We are looking forward to your reply. ![]()
05-30-2019 18:03
05-30-2019 18:03
Best Answer06-01-2019 10:14
06-01-2019 10:14
Hello @Libbymary! The image you tried to attach didn't go through. Can you please try once again to upload the image by following these instructions?
I'm looking forward to your response.
Best Answer06-07-2019 04:40
06-07-2019 04:40
I’ve restarted, I’ve changed the clock face. The “button” is beneath the surface. I believe this is why the clock face is blank.
06-07-2019 09:46
06-07-2019 09:46
Hello there @Libbymary, thanks for coming back and the image provided.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Let me know if there's anything else I may do to assist you with.
06-07-2019 12:11
06-07-2019 12:11
Best Answer07-12-2019 15:45
07-12-2019 15:45
I have the same problem😔How do you solved it?
07-12-2019 15:59
07-12-2019 15:59
Best Answer07-12-2019 16:03
07-12-2019 16:03
OK, thank U👍🏻
Best Answer07-13-2019 08:26
07-13-2019 08:26
Welcome on board @Pacampos! I'm sorry to hear that your Charge 3's button is stuck too.
I've seen you contacted our Support Team after posting here and that they have helped you with this. Please keep an eye on you inbox for updates on your case.
Hey there @Libbymary! I'm glad to hear that our team sent you a replacement. ![]()
Let me know if you both have any questions present, I'll be around.
Best Answer08-16-2019 23:31
08-16-2019 23:31
Hey,
have the exact same problem.
I have the ability to control the watch through the Fitbit app, but the “flat” button does not respond to any kind of pressing.
hope to get help as soon as possible.
Best Answer08-17-2019 07:54
08-17-2019 07:54
Welcome on board @Nadavbr4. If the button on your Charge 3 is not responding, I'd recommend to perform a long restart by following the steps below:
Give this a go and let me know the outcome.
08-17-2019 08:04
08-17-2019 08:04
Tried it already. The button does not do anything.
Best Answer08-17-2019 08:16
08-17-2019 08:16
Thanks for getting back and trying the long restart I've recommended @Nadavbr4.
I went ahead and created a case for you with our Support Team. Someone will reach out to you soon to offer their assistance. Please keep a lookout in your inbox to the email address associated with this account.
Let me know if you have any questions present.
Best Answer08-17-2019 08:37
08-17-2019 08:37
Best Answer08-17-2019 08:57
08-17-2019 08:57
Great news @Libbymary!
I'm very glad to hear that your new device is working as expected.
I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
