02-07-2019
15:08
11:25
02-07-2019
15:08
11:25
Has the screen dimmed after an update or something? It used to be bad, now it's almost useless.
Normal is ok if I cup my hand over it.
Auto works, but is still really dim in bright light.
Dim is non-existent.
It didn't used to be like this. Been horrible for a few weeks.
Hello guys @oweniverson and @Dolbec_83! Thanks for already troubleshooting this inconvenience with your Charge 3.
My friend @RiseAndShine is right, there has been no changes to the brightness of the screen with the last update. For more information, see: What's changed in the latest Fitbit device update?
If you haven't tried to perform a restart yet, please follow these steps:
Hope that helps!
@oweniverson, there has been no changes to the brightness of the screen with the last update. It functions exactly as it used to.
02-11-2019
07:13
08:07
02-11-2019
07:13
08:07
She has the Charge 3?
Mine has definitely changed. It used to be fine, but now it's horrible. I wonder if the different watch faces have different dimming settings...
Update: I see there's an issue with a lot of users having a blank face and the solution seems to be switching watch faces.
As for the dimming, I've tried several different faces and they are all similarly dim.
Hope that helps!
Yes, hers is a charge 3 also. Only difference between ours is mine is the purple limited edition, and hers is the black.
Sitting side by side, same clock faces, Both on "normal" brightness, hers CONSIDERABLY brighter.
I've performed the 15 second restart as per the email support told me, but it didn't make a difference. Mine is still the same- much much dimmer
Thanks for getting back @Dolbec_83! Since you were told to perform a restart by our Customer Support Team, I'd recommend to get back to them with the outcome of the restart. They'll be more than glad to further assist you.
Let me know if there's anything else I may assist you with.
Cant see screen details when outdoors in even slight sunlight.. Totally useless at swimming pool. Very disappointed. Doesn't matter if set at normal,dim,or auto. Never would have purchased , I wanted it for outdoor activity.
Thanks for getting back guys @Gumi1991 and @oweniverson! Also, thanks for following the tips and recommendations provided. I have reached out to our support team and created a case regarding your inquiry. Someone will be reaching out to you within the next 24-72 hours with next steps.
Point me out if there's anything else I can do for you in the meantime.
Best AnswerI have purchased my Charge 3 Special edition very recently. I have noticed that my screen is not as bright as someone else in my office. Is there an issue that people at Fitbit are aware of? Is there a solution?
Welcome to the Fitbit Community @Sanjiv001! There are no issues with brightness reported so far. However, I'll be more than glad to help!
Have you checked the settings? On Charge 3, you can manage basic settings including brightness, heart rate, and button sensitivity directly on your tracker. Open the Settings app and tap a setting to adjust it. Swipe up to see the full list of settings.
If you want to get more information about the basic settings of Charge 3, check here (page 16-20) to see the manual.
Hope this helps, keep me posted!
If his tracker is like mine, it's barely readable in a dark room set to the "Normal" brightness setting.
Set to "Dim" you can't see it in even in a dark room. I had to sit in total darkness for about 10 minutes before my eyes dilated enough to be able to see the display so I could get back to the setting to change it back to "Normal". In normal daylight, you can't see the display at all.
It didn't used to be like this - for the first few months it was completely fine (I've had several trackers now so I know what it's supposed to look like - and this one DID look normal). Then some time in January it just changed. I haven't been able to see the display ever since.
Fitbit is sending me a replacement tracker. I would suggest anyone else with this problem do the same.
Hopefully the replacement is better.
How can you say there are no reported issues?!?!?!? There are many reported issues that the screen isn't right. Mine for starters being a limited edition one too! All I get is a response to do a 15 second restart! I had to threaten action after the screen started to have ghosting to get anyone to ACTUALLY help, and I even had proof with a friends charge 3 and mine side by side showing the difference! Something is dodgy with them! Last fitbit I ever buy! I'll stick to Garmin or spend more for Apple or Samsung.
Best AnswerThank you. Appreciate your feedback. I have only had it for less than 2 weeks so i might be able to return it. Possibly Apple watch. 🙂
Best Answersame problem here. Display is way too dim even in Normal Brightness Mode. It didn't use to be that way. Missing my Charge 2...
@oweniverson wrote:If his tracker is like mine, it's barely readable in a dark room set to the "Normal" brightness setting.
