02-07-2019 15:08 - last edited on 11-17-2020 11:25 by MatthewFitbit
Has the screen dimmed after an update or something? It used to be bad, now it's almost useless.
Normal is ok if I cup my hand over it.
Auto works, but is still really dim in bright light.
Dim is non-existent.
It didn't used to be like this. Been horrible for a few weeks.
12-04-2020 12:45
12-04-2020 12:45
I am having the same issue with my Fitbit. Although I restarted my screen is still dimmed and the screen is barely visible. Please help
12-04-2020 13:10 - last edited on 12-04-2020 18:08 by LiliyaFitbit
Start on the home screen where the time is displayed. Page several screens
to the right till you get to settings.
Tap on settings.
Page up or down till you see "brightness".
Tap on brightness to reset to normal.
Good luck.
12-04-2020 13:27
12-04-2020 13:27
12-04-2020 14:20
12-04-2020 14:20
12-18-2020 09:25
12-18-2020 18:16
12-19-2020 06:33
12-19-2020 06:33
Hello there! Please follow instructions of this post for your Charge 3 display inquiry.
Keep on visiting the forums.
